92-95 throttle body on 90 crx
Old Mar 1, 2006 | 11:30 AM
xxmikexx206's Avatar
Default 92-95 throttle body on 90 crx
is a 92-95 civic si throttle body going to use the wiring connectors as a 90 crx si, i did a mini me swap and want to use a z6 intake manifold but am not sure if the connectors a are the same
Old Mar 1, 2006 | 11:49 AM
si0385.'s Avatar
when i did mine i used the tps and the iacv from the 92-95 and it worked no problem you just gota turn down the idle adjustment screw or its gona idle at like 2 grand but the map sensor and the iacv are the same im sure of that
nudvl
Apr 3, 2008 10:45 PM
rohec04
Feb 18, 2006 03:39 PM
xxmikexx206
Feb 2, 2006 12:56 PM
green91
Sep 13, 2003 10:17 AM
