sway bars
Old Mar 1, 2006 | 10:22 AM
snyderman5's Avatar
Default sway bars
what model hondas have interchangable sway bars with my car, 95 4dr EX
Old Mar 1, 2006 | 11:47 AM
P_Adams's Avatar
Default Re: sway bars (snyderman5)
Any other 5th Gen EX.
You've got the + set-up with regards to 5th Gen Accords already.
From here, you've got to go to either Suspention Techniques or other aftermarket souces if you want to upgrade.
P
Old Mar 1, 2006 | 01:31 PM
importvizion's Avatar
Default Re: sway bars (P_Adams)
exact what p_adams said you can either go with suspension techniques or progress etc... but you can't take sway from another generation.
Old Mar 1, 2006 | 06:27 PM
snyderman5's Avatar
So no other stock bars from say a TL will bolt up without welding in new brackets
Old Mar 1, 2006 | 07:05 PM
wingback44's Avatar
probably not, just get after market ones from eibach or suspension techniques.
Old Mar 1, 2006 | 07:23 PM
philadd's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by snyderman5 &raquo;</TD></TR><TR><TD CLASS="quote">So no other stock bars from say a TL will bolt up without welding in new brackets</TD></TR></TABLE>
Not on 5th gens, only 6th and 7th gens.
Old Mar 2, 2006 | 04:36 AM
YeuEmMaiMai's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by P_Adams &raquo;</TD></TR><TR><TD CLASS="quote">Any other 5th Gen EX.
P</TD></TR></TABLE>
I'm not sure he would want to use the V6 part....might cause some craxy oversteer on a I4
Old Mar 2, 2006 | 07:14 AM
P_Adams's Avatar
Default Re: sway bars (YeuEmMaiMai)
Surprisingly, it goes just the opposite of what you'd expect
Here's how it goes for the 1995 Accord model year:
'95 Accord 4dr LX 4cyl Front Sway Bar: 22.2mm
'95 Accord 4dr EX front bar: 27.2mm
'95 Accord 4dr EX Wagon Front Sway Bar: 27.2mm
'95 Accord 4dr EX V6 Front Sway Bar: 25.0mm
Installing the V6 bar appears to be going in the wrong way.....
In addition: another surprise; Honda offers an OEM strut bar. It's available only with the V6 installation (I'd totally forgot about it)
P
Old Mar 2, 2006 | 02:52 PM
wingback44's Avatar
P</TD></TR></TABLE>
so if i were to find a front sway bar from a 94 EX, it would bolt on to my 94 LX right?
Old Mar 2, 2006 | 04:55 PM
P_Adams's Avatar
Default Re: sway bars (wingback44)
Yes, but remember that you will have to use the EX inner mounting bushings as well (larger diameter.
P
Rob.
Suspension & Brakes
20
Nov 27, 2006 09:20 PM
Ssaacckkeedd
Suspension & Brakes
Nov 26, 2006 08:17 AM
sicivic
Sep 22, 2004 05:43 PM
zebro racing
Sep 17, 2004 10:17 AM
