Oil Leaking into #3 Spark Plug Tube
Old Mar 1, 2006 | 09:47 AM
teletekman's Avatar
Default Oil Leaking into #3 Spark Plug Tube
While at the Honda Dealer recently, the technician had told me that there is oil leaking into the #3 Spark Plug Tube. I had recently changed the valve cover and all spark plug tube gaskets with OEM and tourqed everything down to specs. Assuming nothing is warped which I don't think there is, are there any other gaskets that I need to replace?
From reading other threads on this forum, some say there is a lower tube gasket that needs to be down as well. But I only saw this on a 1990 4-cyl F22 engine. Mine I believe is the F22B. Does mine have this as well?
If it's only the upper gaskets, is there a compund that I need to put on the gasket before installing it? Everything looked real good when I installed them about 4 months ago.
Thanks!
Old Mar 1, 2006 | 09:52 AM
Honda-Master's Avatar
Default Re: Oil Leaking into #3 Spark Plug Tube (teletekman)
go to hondahookup.com .. there is a HOW TO sticky which will tell you step by step instructions
Old Mar 1, 2006 | 11:56 PM
knucklehead11's Avatar
My car does that. We've replaced grommets and the spark plug tube seals from all 4 tubes before and it still leaks oil. Cam tower O-rings need to be replaced.
Old Mar 2, 2006 | 12:50 AM
92ehatch's Avatar
Default Re: (knucklehead11)
http://www.cb7tuner.com/vbb/sh...+tube
all you need to know
Old Mar 2, 2006 | 07:07 AM
teletekman's Avatar
Default Re: (93cb7sedan)
Great, thanks everyone for the replies. Look like I need to replace the lower seals.
Thanks again!
qhiggy
10
Mar 3, 2015 08:49 PM
VTEC_Du_Ma_Mai
Sep 6, 2008 11:08 AM
thegooddoctorceretti
Oct 11, 2007 02:50 PM
luciffer
Mar 18, 2005 07:43 AM
fasteddy91
Apr 4, 2003 08:43 AM
