215/45/17 on a 17" x 7.5" wheel
Old Mar 1, 2006 | 09:30 AM
Type X's Avatar
Default 215/45/17 on a 17" x 7.5" wheel
will it fit?
tirerack.com recomends 225/45/17
the tires are the OEM's from my 06 civic si which comes with 17 X 7's
Any help is appreciated!!
Thanks
- Mike
Old Mar 1, 2006 | 10:10 AM
old man neri's Avatar
Default Re: 215/45/17 on a 17" x 7.5" wheel (Type X)
When you pick out a tire the "spec" will give a range of approved rim widths that that specific tire will fit on.
For example if you look at the "specs" for the Yoko AVS ES 100, Yoko AVS ES 100 spec ,you will see the 6th column says "rim width range" and for the 215/45/17 it has a value of 7"-8". Thus it would be ideal for a 7.5" rim.
This parameter changes from tire model to tire model. You will have to find your spec sheet for your tire. It should be available online.
Cheers.
Modified by old man neri at 3:11 PM 3/1/2006
Old Mar 1, 2006 | 11:08 AM
Type X's Avatar
Default Re: 215/45/17 on a 17" x 7.5" wheel (old man neri)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by old man neri &raquo;</TD></TR><TR><TD CLASS="quote">When you pic out a tire the "spec" will give a range of approved rim widths that that specific tire will fit on.
Cheers.</TD></TR></TABLE>
Thanks
i was doing it backwards putting in a " random rim" and it comes with recommended tires lol
Thanks again!
Old Mar 1, 2006 | 11:12 AM
Do you need help in selecting the tire or have you already purchased them?
Old Mar 1, 2006 | 11:21 AM
Type X's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by old man neri &raquo;</TD></TR><TR><TD CLASS="quote">Do you need help in selecting the tire or have you already purchased them?
i'm actually going to be running my OEM tires off my 2006 civic si
on my Volk te37's
just burn them up and once i decide on which suspension to go with than decide
but thanks for the help!
Old Mar 1, 2006 | 11:23 AM
Type X's Avatar
this is the spec sheet for my oem's
http://www.tirerack.com/tires/...4HXV3
and it says 7-8" so i should be good!
WOOT
ManjuGrip
Feb 1, 2007 10:17 AM
honda95civic
Mar 27, 2005 08:10 PM
FBP Si 2000
10
Dec 29, 2003 11:30 AM
hypa
Feb 14, 2003 03:40 PM
