JDM OBDII spec GSR doesn't have oil pressure switch?
anyone run into this problem...of course the ecu is OBDI, therefore code 22....
oil pressure switch, is tapped for but blocked of orignally???any ideas on making this work????
I know that JDM ITR motors don't have the VTEC pressure switch. Didn't know that the JDM GSR was the same.
I guess the easiest solution would be swapping in a USDM VTEC solonoid.
Code 22 gone.
Code 22 gone.
Or you could just ground the wire that goes to the oil pressure sensor. Thats all the switch does. When the oil pressure shows up, the switch closes the circuit to ground.
whophlungpoo
10
Oct 1, 2006 10:52 AM
GummyBeng
Feb 17, 2003 08:18 AM
