Getting a Code 21??
Old Mar 1, 2006 | 08:28 AM
Rukusmasta2's Avatar
Default Getting a Code 21??
wussup guyz my CEL is getting a code 21. VTEC spool solenoid valve. What could it be from???
Old Mar 3, 2006 | 11:09 PM
Default Re: Getting a Code 21?? (Rukusmasta2)
BUMP Getting a 4 and 14 as weel HELP
Old Mar 3, 2006 | 11:43 PM
theinfamouskonrad's Avatar
code 21- Make sure the solenoid is hooked up to the right pin by the ecu.
code 04- Inside your dizzy, you could possibly have a bad dizzy.
code 14- eacv valve on the back of your intake manifold....possibly could be clogged up. Take off 2 12mm bolts that hold it on, and clean with carb cleaner then re-install. If you still throw the cel check the wiring that goes to it.
Old Mar 4, 2006 | 07:02 AM
Default Re: Getting a Code 21?? (theinfamouskonrad)
thanx bro ill check it out...but i doubt the dizzy is fucked up i dont understand how it could it came out of a perfect running car???
Old Mar 4, 2006 | 09:21 AM
ok so i check the code 14 was a wire that had broke off...so i fixed that for the code 4 i figured swapping the 2 wires that i had to run for the DPFI-MPFI SWAP and that code went away but no i got a code 9 this **** is crazy
Bunger
Sep 12, 2011 09:00 AM
asocallocal
Jun 6, 2010 11:30 AM
wvudelsol
Dec 31, 2008 04:01 PM
1_SC_GSR
Aug 14, 2006 10:24 PM
vtechrex
Jul 10, 2006 06:21 PM
