Aebs Intake manifold Install. Question with coolant lines?
I am just finishing up installing The AEBS manifold and an ITR throttle body but have run into a problem.
There are two coolant lines that I need to figure out where they go. One coming off of the thermostat and the one that comes off the manifold. These lines are the same size(not the big ones). With my old setup the one from the manifold went to the FITV and the one off of the thermostat went to the IACV( i think).
Should I just cap one of them off? Do they make coolant line caps?
From what I understand all I need is one of these lines to run to the Throttle body inlet nipple, out of the throttle body outlet nipple, and into the IACV.
I know i can bypass the throttle body but I Drive my car in the winter so im going to keep it.
The AEBS doesn't come with the FITV port so if you want the FITV you have to get an OBD 1 throttle body that has it on the bottom. Otherwise you just have to bypass it. The easiest way to loop is to just use an inline connector and tie the two hoses together or use 1 long hose.
marshall12395
May 15, 2014 08:17 AM
waynesumner
10
Jun 7, 2013 10:30 AM
4DRmafia
Sep 3, 2005 10:17 AM
