Enkei RPF1 15x7 +35 & +41 offset ?
Old Mar 1, 2006 | 07:24 AM
Rob.'s Avatar
Default Enkei RPF1 15x7 +35 & +41 offset ?
I wanna buy a set of these for my crx in the springtime.
Whats the difference between these offsets ?
what should I go with ?
Old Mar 1, 2006 | 07:32 AM
Fobtions's Avatar
Default Re: Enkei RPF1 15x7 +35 & +41 offset ? (Rob.)
41 would be your best bet, you can run a azenis 205 which is pretty wide.
35 you would rub with even a 195/50/15. on a crx
Old Mar 1, 2006 | 07:33 AM
Rob.'s Avatar
Default Re: Enkei RPF1 15x7 +35 & +41 offset ? (Fobtions)
wouldnt +41 be a lil too 'inside' the wheel well ?
I wanna run 195/45 15 tires
oh, and would these wheels be easily bendable ? or are they strong ?
IS THIS GUY USING +41 OR +35 offset ?
Old Mar 1, 2006 | 07:42 AM
90civichbsi's Avatar
i have some 15x7 +42 gram lights on my hatch and they sit pretty flush
Old Mar 1, 2006 | 07:43 AM
Fobtions's Avatar
in that case go with the 35, it will be more flush with the fenders.
Old Mar 1, 2006 | 07:50 AM
GSRCRXsi's Avatar
you will rub with a 35. get the 41. its a better offset.
Old Mar 1, 2006 | 07:53 AM
Broke EF's Avatar
Go with the +41. Thats whats on my car and they look awsome. It sounds like a lot of offset but it really isnt. As far as strength they didnt do all that great going over a curb.
Before they faught the curb and lost.
Messed up wheel 1
Messed up wheel 2
Hope this helps
Sean
P.S. According to Enkeis website the +41's are a half a pound lighter too.
Old Mar 1, 2006 | 07:58 AM
turbotommy's Avatar
Default Re: (Broke EF)
go with the 41...my rotas are +40 and i dont rub with 215's on all 4 corners
Old Mar 1, 2006 | 10:08 AM
fireant's Avatar
Default Re: (turbotommy)
+41 == perfect fit, no rubbing
Old Mar 1, 2006 | 10:35 AM
UltimX's Avatar
Default Re: (fireant)
how strong would u expect a rim that light to be? don't go over curbs and pot holes
Old Mar 1, 2006 | 10:53 AM
jaydmcrx's Avatar
Default Re: (UltimX)
they are forged. forging is a process in wich you take a piece of hot metal and stamp it into a shape. This keeps the grainular structure of the metal at its optimal strength level. Wich is why they are lighter, stronger, and more expensive. But nothing is indestructable. If your not going to track the car i don't see a reason to buy a forged wheel. I track my car and i don't have a forged wheel. If you have the money then i say go for it. Otherwise they make a nice knock off of that wheel.
NACvicSi's Avatar
so +35 is wider than +41? How does this work. I have always wondered while looking at rims.
Old Mar 1, 2006 | 11:04 AM
juice91si's Avatar
Default Re: (NACvicSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NACvicSi &raquo;</TD></TR><TR><TD CLASS="quote">so +35 is wider than +41? How does this work. I have always wondered while looking at rims.</TD></TR></TABLE>
thw lower the offset, the more the wheel will stick out.
increasing offset, will suck the wheel back into the fenderwell.
Targa250R's Avatar
be professional
http://www.tirerack.com/wheels...d=101
Old Mar 1, 2006 | 06:07 PM
Rob.'s Avatar
hmmm,
maybe I should just stick with my old skool asa wheels ! Built tough !
Old Mar 1, 2006 | 07:10 PM
88 rex's Avatar
41+ offset....great wheels
JG90CRX-Si
Jun 2, 2009 10:18 AM
speedehatch
Sep 29, 2004 12:22 PM
highmilehatch
May 7, 2003 08:22 AM
tylerdurden
Dec 1, 2002 08:28 AM
