ground point on tranny, ball joints
Old Mar 1, 2006 | 06:54 AM
shutta's Avatar
Default ground point on tranny, ball joints
4th gen, I can't figure out where the ground point is on teh tranny, the only point I see I can't move the groudn cable to.. anyone have a pic of it?
also, anyone have any tips on tightening bal joint castle nuts? I keep spinning the ball joint and can't tighten the nut. this is on the tie rod end btw.
Old Mar 1, 2006 | 07:14 AM
Honda318dx's Avatar
Default Re: ground point on tranny, ball joints (shutta)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shutta &raquo;</TD></TR><TR><TD CLASS="quote">4th gen, I can't figure out where the ground point is on teh tranny, the only point I see I can't move the groudn cable to.. anyone have a pic of it?</TD></TR></TABLE> There is a braket right below the starter motor.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">also, anyone have any tips on tightening bal joint castle nuts? I keep spinning the ball joint and can't tighten the nut. this is on the tie rod end btw.</TD></TR></TABLE>
put a jack under the suspension, get a block of wood (cut to fit at full suspension droop), put it between the balljoint and the fender well. Jack up the suspension until there is pressure on the top of the balljoint, then tighten the nut..
Old Mar 1, 2006 | 08:32 AM
shutta's Avatar
the tie-rod end has too m uch up and down movement to do that trick.. i'm going to try to c clamp the top of the rod end and the knuckle and se eif that works.. not much room to work with though
Old Mar 1, 2006 | 08:51 AM
Honda318dx's Avatar
Default Re: (shutta)
I don't think you understand what I'm saying.. Up and down movement won't matter..
Old Mar 1, 2006 | 09:19 AM
shutta's Avatar
oh ok, i get it now.. cut a block of wood.. i'll try that. i read it too quick i guess
Old Mar 1, 2006 | 09:25 AM
shutta's Avatar
anyoen have a pic to pint out that ground point
Old Mar 1, 2006 | 09:34 AM
mgags7's Avatar
#4 in the pic, its bolted on right below the starter
RyanStevenPhillips
Oct 7, 2008 07:11 AM
whp
Feb 10, 2007 07:22 PM
SoOHiGH
Jul 13, 2005 05:49 PM
Eg6_rAcEr
Sep 23, 2004 08:00 AM
Log4n
Apr 14, 2003 09:09 AM
