A way to brighten gauge lights?
Old Feb 28, 2006 | 06:18 PM
Andrew Marquis's Avatar
Default A way to brighten gauge lights?
Just wondering if there is a simple fix for dim bulbs? replacement?
if so, how to??
Thanks
-Andrew
Old Feb 28, 2006 | 06:22 PM
paopao's Avatar
Default Re: A way to brighten gauge lights? (bakerboy4679)
Taking the cluster out is pretty easy. You have to remove the cluster cover which has 2 screws in the back and two in the front. Then just unscrew the cluster from the car.
You can also remove an opaque orange film that's at the top of the gauge cluster. It won't be backlit anymore but it'll be a lot brighter, because light is projected directly onto the gauges instead of being dispersed through the orange film.
Old Feb 28, 2006 | 06:23 PM
DEIVIONCRX's Avatar
i dont know if normal incandescent light bulbs deminish light output over time, but it probably couldnt hurt, just take the few screws that hold the cover on, out, theres 4 screws tha hold the cluster to the dash, then theres a SpeedO cable, and 3-4 wiring conectors unplug them and take it out
Old Feb 28, 2006 | 06:26 PM
Jonknee's Avatar
Default Re: A way to brighten gauge lights? (DEIVIONCRX)
yeah i took that orange crap off the top, and took the blue rubber covers off each light bulb and made it a bit better looking.
Old Feb 28, 2006 | 06:30 PM
Default Re: A way to brighten gauge lights? (efnewb91)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by efnewb91 &raquo;</TD></TR><TR><TD CLASS="quote">yeah i took that orange crap off the top, and took the blue rubber covers off each light bulb and made it a bit better looking.</TD></TR></TABLE>
I might try this.
Could someone link me to a Write-up on taking out the gauge cluster?
Thanks guys! such helpfullness!!!
-Andrew
Old Feb 28, 2006 | 06:46 PM
Default writeups por favor
any write-ups handy anyone?
Old Feb 28, 2006 | 07:57 PM
d16efsedan's Avatar
Default Re: writeups por favor (bakerboy4679)
on my cluster i just removed the blue light rubbers and it helped alot but then i painted the bulbs amber...its pretty bright though still......
Old Feb 28, 2006 | 08:04 PM
Jonknee's Avatar
I tried to do this asap, might be hard to understand since i took bad photo angles and bad photoshop, but im lazy and yeah.
These two are each in the opposite side of the steering wheel.
Theres another exact bolt on the other side.
Old Mar 1, 2006 | 10:43 AM
Default Re: writeups por favor (efnewb91)
In the second pic, is the screw right above the white button-thingy required, since on the first pic you took it out as well?
Thanks a lot!
I'll make sure to do a walkthrough when i do mine(right now)
-Andrew
JUNKH34D
Aug 6, 2010 07:31 AM
blueDA9
Feb 4, 2008 07:17 PM
jchrm80
Nov 9, 2007 08:52 AM
02 accord
May 5, 2006 05:30 PM
RTW DC2R
May 23, 2004 06:20 PM
