will 94 and up gsr spindles fit on an ef
Old Mar 29, 2002 | 02:59 PM
dinkydx's Avatar
Default will 94 and up gsr spindles fit on an ef
i have a set and i would like the bigger brakes
thank you
Old Mar 29, 2002 | 03:06 PM
CRX-RX's Avatar
Default Re: will 94 and up gsr spindles fit on an ef (civicprelude)
not properly
Old Mar 29, 2002 | 07:45 PM
wickedxboi's Avatar
Default Re: will 94 and up gsr spindles fit on an ef (CRX-RX)
im pretty sure they will fit cause i have the brakes off a 93 gsr on my rex.....pretty sure the 94 and up are the same
Old Mar 29, 2002 | 08:27 PM
CRX-RX's Avatar
Default Re: will 94 and up gsr spindles fit on an ef (wickedxboi)
Yes, and if you used the spindles, if you haven't already, you will go through axles like crazy. They are a half inch taller than the CRX spindles which will cause a lot of positive camber, and won't let the axle line up right. If your car is dropped. you won't notice the camber, except that you would no longer need a kit to correct it. Sell those for some cash, and find a set of 90-1 Civic Sedan EX spindles. Somone swapping on a later gen hatch can make good use of them.
ef9robert
Sep 11, 2008 01:30 PM
Davidkak
Jun 25, 2008 10:21 AM
articsilber323
Feb 8, 2008 01:32 PM
drintegra
Aug 3, 2006 01:50 PM
EfSedanLove
May 17, 2006 03:45 PM
