How much can a thicker headgasked lower compression by?
Old Mar 29, 2002 | 01:43 PM
Black R's Avatar
25 Year Member
Default How much can a thicker headgasked lower compression by?
Is there a limit? I'm assuming that too thick and you'll need a different timing belt.....
But is it possible to go from stock 10.6:1 to 9.6:1?
Old Mar 29, 2002 | 01:45 PM
Ross's Avatar
25 Year Member
Community Builder
Community Influencer
Active Streak: 30 Days
Default Re: How much can a thicker headgasked lower compression by? (Black R)
thinking of going FI Ken?
Old Mar 29, 2002 | 01:48 PM
Black R's Avatar
25 Year Member
Default Re: How much can a thicker headgasked lower compression by? (Ross)
.....uhh it's for a "friend."
You think I'm gonna turn in the towel now that I have spec b's, spec c's, toda header and hytech header?
Hrm... maybe if I sell the b's and toda header I can pay for a turbo kit.....
Seriously though, the beater needs some b00st!
Old Mar 29, 2002 | 02:04 PM
TurboTypeR98's Avatar
New User
I believe dropping compression to 9.6:1 is doable with stock timing belt. I have the HKS headgasket(2.6mm) and I was told that it drops compression to ~9.5:1 and I still have a stock timing belt. But my compression may be even lower then 9.5:1 b/c when I use compression ratio calculators they say I have 9:1 compression. But I am not sure if the calculators are accurate.
Old Mar 31, 2002 | 11:25 PM
t's Avatar
t
HKS makes thicker headgaskets for lowering compression, although they cost about $550.00
Old Apr 1, 2002 | 12:01 AM
ingrate's Avatar
25 Year Member
Default Re: How much can a thicker headgasked lower compression by? (t)
i don't think you'll need a different timing belt because you tighten it down with the tensioner
Old Apr 1, 2002 | 05:38 AM
Mike K's Avatar
Default Re: How much can a thicker headgasked lower compression by? (In7egrity)
Cometic .056" lowers B18C5 to 9.9:1
Old Apr 1, 2002 | 05:44 AM
Black R's Avatar
25 Year Member
Default Re: How much can a thicker headgasked lower compression by? (Mike K)
Wow, that's like .7 of a point!
Any way you can run an even thicker headgasket to bring 11.1:1 to 9.5 or so?
Old Apr 1, 2002 | 06:01 AM
Tomakit's Avatar
http://www.inlinepro.com makes gaskets for FI apps that lower CR to 9.0 to 1 for a few different motors i think.
Tom
Mad Cow Disease
May 20, 2004 11:30 AM
lilcasino
Nov 20, 2002 08:37 AM
Mr.Integra
Sep 8, 2002 12:06 AM
MOTOR R
Apr 23, 2002 05:02 PM
