What is the Inner Diameter of OEM ITR springs?
What springs you talkin' bout Willis? Valve springs inner/outer;intake/exhaust or suspension springs front/rear?
Hmm, 70 MM at the top? That converts out to about 2.755 inches, dammit. That means I can't run GC tophats with OEM ITR springs or H&R sports since they should be the same right?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hungsteR »</TD></TR><TR><TD CLASS="quote">Hmm, 70 MM at the top? That converts out to about 2.755 inches, dammit. That means I can't run GC tophats with OEM ITR springs or H&R sports since they should be the same right?</TD></TR></TABLE>
I would assume that the GC top hats are meant to be used with 60mm ID springs.
Your best bet to is to call GC and ask them, as their customer service has always been great when I've called.
juniordc2
Suspension & Brakes
May 8, 2005 01:50 PM
HapiHonda
Oct 21, 2002 03:08 PM
