Front LCA mix and match for RSX?
I need a new front LCA, but am hesitant to pay $240 for a new one from Acura. I have a 2005 arm that I thought would fit, but it does not. The ball joint hole for 2005 models is MUCH larger. I'm wondering if anyone knows if the 2005 spindle/wheel bearing will fit a 2002 rsx, assume I also have a 2005 lower arm? It appears the only difference might be the wheel bearing where the axle goes through.
