K & N airfilter.... Is it worth $50?
Old Feb 28, 2006 | 07:21 AM
HondaJack's Avatar
Default K & N airfilter.... Is it worth $50?
I was looking to get a K & N air filter for my CRX 1.5 liter. I live 2 miles back a dirt road so I dont think a cold air intake is a good idea.
Is the K&N worth $50?
Is there anyplace to get one cheaper?
Old Feb 28, 2006 | 07:22 AM
CRX Toad's Avatar
Default Re: K & N airfilter.... Is it worth $50? (HondaJack)
Your talking about a K&N that fits in the stock air box? For your application it is probably not worth it. Personal preference is bliss though.
Old Feb 28, 2006 | 08:14 AM
HondaJack's Avatar
Default Re: K & N airfilter.... Is it worth $50? (CRX Toad)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX Toad &raquo;</TD></TR><TR><TD CLASS="quote">Your talking about a K&N that fits in the stock air box? For your application it is probably not worth it. Personal preference is bliss though. </TD></TR></TABLE>
Yep stock airbox.
Thanks
Old Feb 28, 2006 | 08:27 AM
si0385.'s Avatar
if your looking for extra protection because you live on a dirt road than its worth it but performance wise it wont make a difference in your application
Old Feb 28, 2006 | 08:34 AM
ghost_ryder35's Avatar
Default Re: K & N airfilter.... Is it worth $50? (si0385.)
^^^^^ agreed
Old Feb 28, 2006 | 08:46 AM
Floored's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by si0385. &raquo;</TD></TR><TR><TD CLASS="quote">if your looking for extra protection because you live on a dirt road than its worth it but performance wise it wont make a difference in your application</TD></TR></TABLE>
Actually a K&N filter is going to be worse off protection wise. They are high flow filters, so you are more likely to get unwanted debris in your engine than with just the stock filter(especially if you live on a dirt road). Also as others have noted you wont see a noticeable gain in performance, just a more profound intake noise.
Old Feb 28, 2006 | 09:20 AM
si0385.'s Avatar
Default Re: K & N airfilter.... Is it worth $50? (Floored)
a k&n filter does not provide better protection for your motor but it provides the same amount of protection as a paper filter for a longer time and they are cleanable and re-usable... hence why its better for your car if you live on a dirt road paper filter will clog up alot faster and when tehy clog up they no longer protect your engine
if they did not filter as good as a factory filter than manufacturers would not warranty them
Old Feb 28, 2006 | 09:46 AM
mstolars's Avatar
Technically, the K&N filter will pay for it self after a year or 2, because instead of changing filters every other oil change, you can just clean the K&N.
Old Feb 28, 2006 | 10:01 AM
Floored's Avatar
if they did not filter as good as a factory filter than manufacturers would not warranty them</TD></TR></TABLE>
It isnt that they filter bad, it is just that they dont filter as well. Check this article out, it is pretty interesting.
http://www.bobistheoilguy.com/...3.htm
Old Feb 28, 2006 | 07:10 PM
rbjeepthing's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Floored &raquo;</TD></TR><TR><TD CLASS="quote">
http://www.bobistheoilguy.com/...3.htm</TD></TR></TABLE>
The funny thing is any filter that flows more will filter less come on guys it's just common sense. However alot of guys run a K&N and have no abnormal effects from it. I have 340,000km on my car and it still runs great!
Old Feb 28, 2006 | 07:37 PM
Crx Jimmy's Avatar
Default Re: floored
but that test was only 500 miles, according to k&n when the filter starts to become dirty it actually helps the filtration, that filter was just broken in I would like to see the next 1000 miles.
Old Feb 28, 2006 | 08:04 PM
juice91si's Avatar
Default Re: floored (Crx Jimmy)
i got mine for 15 bucks, 5 more than a replacement paper one, so why not.
i wouldnt pay 50.
tpot90
Nov 11, 2007 04:02 PM
disrupter006
12
Sep 27, 2007 08:31 AM
AnAccordIsForever
Jun 26, 2007 04:25 AM
petec59
Honda Civic (2006 - 2015)
14
Apr 21, 2007 02:36 AM
non-VTEC
Oct 4, 2003 07:42 PM
