where is the oil pressure sending unit on my 94 integra rs??
i got my oil pressure guage today, and its a mechanical one with the steel oil line too, but where abouts is the oil sending unit?? someone said it was above the oil filter?????? help me fast!!!
go underneath the car, look at your oil filter location. To the left of it(towards driver side) is where it is..it is a rubber boot with wires comingout of it
what you need to do is slowly and carefully take out the wire boot, then you can see the oil pressure sender. Use a (I think) 5/8" deep socket or maybe bigger to undo it, then install a Tee to where you can tee off the stock sender and the one to the gauge..
HTH
stan
HTH
stan
standbackimapro
Apr 30, 2006 07:22 PM
Acura_I-RS
May 12, 2002 05:20 AM
Acura_I-RS
Mar 29, 2002 02:10 PM
