Brakes swap question...
Old Feb 28, 2006 | 06:44 AM
dude9571's Avatar
Default Brakes swap question...
I'm looking at swapping out drum brakes for disc brakes. Is it possible to do? I have a 94 Accord LX Sedan and was thinking about swapping the rear drum brakes for rear disc brakes from a 94 or 95 EX model. I know they are all ABS, but does it make any difference? Like, would do the calpiers need the ABS computer to work? Is the entire brake assembly interchangeable between all model 94-97 Accords?
Also, since the EX model has a 2nd brake fluid tank(as seen here: http://i50.photobucket.com/alb...s.jpg ), would I have to run that to the brakes when I install it?
If this isn't possible or is more work than it's worth, how else can I improve the stopping ability of my brakes, other than changing the pads and fluid?
Old Mar 1, 2006 | 01:39 PM
94 exr's Avatar
the second tank you see is your clutch reservoir
Old Mar 1, 2006 | 03:38 PM
Nick H's Avatar
New User
Default Re: Brakes swap question... (dude9571)
the abs system is of no concern....there is a complete writeup of this brake swap (as well as others) at http://www.accordinglydone.com ....it should answer just about every question you have...it should be under the tech forum...good luck
Old Mar 1, 2006 | 04:23 PM
Diego Dangers.'s Avatar
Default Re: (94 exr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94 exr &raquo;</TD></TR><TR><TD CLASS="quote">the second tank you see is your clutch reservoir</TD></TR></TABLE>
Old Mar 1, 2006 | 07:15 PM
dude9571's Avatar
Default Re: (Diego Dangers.)
Seriously? I could almost swear the cap says DOT3 brake fluid only...I could be wrong, though.
Old Mar 1, 2006 | 07:17 PM
dude9571's Avatar
Default Re: Brakes swap question... (Nick H)
Sweet...thanks!!
CD5B2
Oct 14, 2013 04:12 PM
Syndacate
Apr 23, 2006 05:29 PM
Jagan'92
Dec 20, 2003 02:22 PM
94si94cx
Sep 30, 2002 08:57 PM
Kamin
57
Mar 20, 2002 10:55 AM
