Wat tire size so that no rub?? Need ur Opinions!!
Old Feb 27, 2006 | 04:32 PM
2civic3's Avatar
Default Wat tire size so that no rub?? Need ur Opinions!!
Hey guys, I have this 15x7 and dont know what the offset is, I'm just wondering what is the best tire size for the rims so there is no rubbing on the fenders when I drop my car 2" to 2.5"??? By the way, im driving a 94 H/B dx.
Is it:
- 195-50-15
- 195-55-15
- 205-45-15(is this size exist??)
- 205-50-15
Thanks in advance for all your opinions and experiences
John
Modified by 2civic3 at 6:07 PM 2/27/2006
Old Feb 27, 2006 | 04:51 PM
Mike_C's Avatar
i have never seen a 205/45/15. your best bet is one of the 195s, but that depends on what car you have.
Old Feb 28, 2006 | 01:14 AM
dreww..'s Avatar
Go with the 195/50/15...Had them on my old EG, and I was pretty low...
Old Feb 28, 2006 | 07:26 AM
pingaturbo's Avatar
As for the offset of the wheel, look at the back of the wheel. It should say ET 35,42 etc. This would be the offset, any further questions just ask.
Old Feb 28, 2006 | 09:20 AM
Fobtions's Avatar
Default Re: (pingaturbo)
the 195/50/15 would be your best bet, in an extreme case some use 195/45/15 may not be the best handling package but it will not rub
Modified by Fobtions at 10:38 AM 2/28/2006
Old Feb 28, 2006 | 09:36 AM
Mike_C's Avatar
Default Re: (Fobtions)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fobtions &raquo;</TD></TR><TR><TD CLASS="quote">in an extreme case some use 165/45/15</TD></TR></TABLE>
whaaaat? that is like a donut.
Old Feb 28, 2006 | 09:38 AM
Fobtions's Avatar
Default Re: (Mike C)
oops i meant 195/45/15
Old Feb 28, 2006 | 12:06 PM
Clay@tirerack's Avatar
Honda-Tech Sponsor
195/50/15 is the correct size to use.
Old Feb 28, 2006 | 03:20 PM
nsxtasy's Avatar
H-T Order of Merit
Default Re: (Clay@tirerack)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Clay@tirerack &raquo;</TD></TR><TR><TD CLASS="quote">195/50/15 is the correct size to use.</TD></TR></TABLE>
Old Feb 28, 2006 | 05:58 PM
2civic3's Avatar
So if I put 195-50-15 on to my 15x7 rims, is the offset really matters or not?
Old Feb 28, 2006 | 08:08 PM
nsxtasy's Avatar
H-T Order of Merit
Default Re: (2civic3)
The offset still matters. The wheel should still have an offset that positions the tire so that it's not too far in towards the car, or too far out away from the car, where it may rub on the wheel well liners, fender, etc.
The tire size also matters because the chances of rubbing increase when you use a tire size whose diameter is larger than stock. But you'll be okay with 195/50-15, as long as the wheels have the proper offset.
Hope that makes sense.
icefirezero
Jun 5, 2006 11:16 PM
chu888
Jun 2, 2006 05:48 PM
jdmhatch3
Aug 11, 2005 04:50 AM
VoltageLS
Feb 23, 2003 12:10 AM
hybrid_eg
15
Feb 10, 2003 12:59 AM
