Axle swapping
Old Mar 29, 2002 | 10:25 AM
kurt.'s Avatar
Default Axle swapping
What do you do with the Prelude 'donor' axles during an H22 swap? Do you discard them and use your Accord axles or is it best to use the Prelude axles? Would you then have to use the 5-lug hubs for a Prelude as well?
As you can tell, I'm confused. I've looked around for this information and I haven't found anything relevant to H22's.
Thanks in advance
Old Mar 29, 2002 | 10:41 AM
John's Avatar
New User
Default Re: Axle swapping (Vantage)
Talk to Dave...
Old Mar 29, 2002 | 10:58 AM
H23 Power's Avatar
Default Re: Axle swapping (DunReit)
the axles are too long to use on the accord...i would sell them if they are in good condition...
you need to use accord axles for the H22 swap
Old Mar 29, 2002 | 11:21 AM
4doorH22's Avatar
Default Re: Axle swapping (01GSR)
5G Prelude axles are longer than 4G Prelude (VTEC) axles.
My 4G Accord hybrid needed 4G Prelude axles. Accord axles are useless to me. I do not know what generation you Accord is, nor which axles other generation Accord hybrids require.
Old Mar 29, 2002 | 11:23 AM
kurt.'s Avatar
They are interchangeable then? Cool. Should I upgrade the axles as long as the motor and trans are out of the car or are the stock Accord axles stout enough to handle the H22?
Old Mar 29, 2002 | 11:30 AM
4doorH22's Avatar
w h a t y e a r i s y o u r A c c o r d ?
Old Mar 29, 2002 | 11:36 AM
kurt.'s Avatar
Default Re: Axle swapping (4doorH22)
sorry, I missed your post. I don't have it yet, but it will be a 5th gen wagon when I get it.
Old Mar 29, 2002 | 12:12 PM
Fly1865's Avatar
From what i've been seeing and what i've done, 5th gen Accord, 98 H22A needs the Accord axles and half shaft. now if it was a 93-96 H22A then it might use the H22A axles, not really sure about it.
Old Mar 29, 2002 | 03:12 PM
scrubachu's Avatar
Default Re: Axle swapping (Fly1865)
all hybrid swaps need accord axles and intermediate shaft. end of story.
Old Mar 29, 2002 | 03:15 PM
4doorH22's Avatar
Default Re: Axle swapping (scrubachu)
Old Mar 29, 2002 | 04:07 PM
scrubachu's Avatar
really 4door. that is interesting.... what intermediate shaft you using? i know that the outer teeth on the lude axles are too small to fit into the accord hub. ive tried, and it just spins inside there. did you convert your hub & rotor setup?? i have a 4th gen also with 95 h22, thats why im wonderin. i know a shop did your sawp, so just makin sure for info purposes
Old Aug 31, 2002 | 11:41 PM
sloaccord's Avatar
New User
well, my 4th gen accord re-used my accord axles, as did my roommate's 5th gen. both cars have 94 motors.
Old Aug 31, 2002 | 11:45 PM
Accord94DX's Avatar
Default Re: Axle swapping (sloaccord)
i switched to prelude axles on my accord. they hold up better to nitrous launches.
Old Aug 31, 2002 | 11:58 PM
Brandon's Avatar
Life is Suffering
Default Re: Axle swapping (Accord94DX)
Took you 13 tries to figure it out too...
Old Aug 31, 2002 | 11:59 PM
Accord94DX's Avatar
Default Re: Axle swapping (F22turbo)
12 you dick.
Old Sep 1, 2002 | 02:18 AM
ichibanjap's Avatar
I have prelude axles too. My motor is 95 and my car is 94. But i do have a problem with my bearings going bad, could this be the reason?
Old Sep 1, 2002 | 03:34 AM
sloaccord's Avatar
New User
Default Re: Axle swapping (ichibanjap)
well, i've had the accord axles for exactly a year with no problems. lots of track launches, autocrosses. . . my roommate had a 270 hp accord hybrid on accord axles and no problems, with a quaife, etc. . . just my opinion.
Old Sep 1, 2002 | 10:17 AM
4doorH22's Avatar
Oh whoa this is an old thread. Yeah I was totally wrong I have Accord axles and intermediate shaft.
4th gen Prelude axles/int shaft are supposedly identical except have a male end on the int shaft and a female end on the inside of the driver-side axle.
Old Sep 1, 2002 | 02:32 PM
billk2k's Avatar
I have a 95 accord ex and a 95 JDM prelude motor with LSD. I am using the prelude axles and have not had any problems yet.
CTCD5
Mar 10, 2017 12:11 AM
ricedaccord
Jun 16, 2011 01:12 AM
Twixle
Sep 4, 2010 09:20 AM
H2Os
Apr 27, 2006 06:02 AM
femmefataleracer
Sep 25, 2004 04:25 PM
