Want to Buy Want to Trade/Want to Buy
WTB: All parts needed for Auto->5spd for 92-95 Ex Civic w/ b18b1 swap
Old Feb 27, 2006 | 02:37 PM
[Ennis_D]'s Avatar
Default WTB: All parts needed for Auto->5spd for 92-95 Ex Civic w/ b18b1 swap
Like title says...Looking for parts needed for Auto->5spd conversion for 92-95 Ex Civic with b18b1 swap. Car is now auto and looking to convert to 5spd. while everything is out.
Looking for:
Hydro LS Tranny (good, working condition)
B-Series Clutch/Flywheel/Pressure Plate
Clutch Resovir
Hydraulic Lines
Slave Cylinder (Bought: Thanks I am USDM!!!)
Master Cylinder (Bought: Thanks I am USDM!!!)
5spd OBD1 LS ECU
5spd Pedal Assembly for 92-95 Civic (Bought: Thanks I am USDM!!!)
5spd Throttle Cable for 92-95 Civic
Shift Linkage (Bought: Thanks I am USDM!!!)
Manual Console Piece for 92-95 Civic (Black)
Shifter Bushings
Located in Upstate SC...Looking for things local but willing to pay shipping to get these ASAP! Lets help a brotha out!
Modified by Trock1029 at 4:44 PM 3/15/2006
Old Feb 27, 2006 | 05:44 PM
hatchi's Avatar
Default Re: WTB: All parts needed for Auto->5spd for 92-95 Ex Civic w/ b18b1 swap (Trock1029)
i have all the parts for your auto to manual swap except for ecu and tranny.
Old Feb 27, 2006 | 06:08 PM
[Ennis_D]'s Avatar
Default Re: WTB: All parts needed for Auto->5spd for 92-95 Ex Civic w/ b18b1 swap (hatchi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatchi &raquo;</TD></TR><TR><TD CLASS="quote">i have all the parts for your auto to manual swap except for ecu and tranny. </TD></TR></TABLE>
You got PM!
Old Feb 27, 2006 | 07:38 PM
[Ennis_D]'s Avatar
Replied!
Old Mar 1, 2006 | 05:27 AM
vtecb20coupe's Avatar
B A N N E D
just the clutch master cylinder and pedals.
http://hondamarketplace.com/zerothread?id=1543308
Old Mar 1, 2006 | 11:23 PM
_Justus's Avatar
Default Re: WTB: All parts needed for Auto->5spd for 92-95 Ex Civic w/ b18b1 swap (vtecb20coupe)
TTT!
Old Mar 2, 2006 | 07:19 AM
klungemonger's Avatar
I have an OBD1 manual trans P75 ecu...for the B18B engine.
Old Mar 2, 2006 | 03:18 PM
I am USDM's Avatar
Default Re: (klungemonger)
ive got the entire pedal assembly, all lines, and the clutch m/c for sale out of a 97 integra! and im located in greenville!
-Daniel
edit: actually im parting out the whole integra and was planning on keeping the swap for myself, but id be willing to sell if the price is right... it would be EVERYTHING you need to do a swap minus the ecu...
ok... PM sent
Old Mar 2, 2006 | 08:20 PM
_HANS's Avatar
From: new jersey home of wanna be's posers claimers ricers biters and where everyone fakes the funk
i have the 5 speed pedals from my 98 itr.should fit. eg and dc are the same
and everything else u would need
Old Mar 2, 2006 | 09:03 PM
not so civic's Avatar
From: gravity rides everything...everything will fall, se GA/ne FL
i have:
-transmissions, speed sensors
-all hard and soft hydraulic lines and fittings
-master cylinder
-slave
-release bearing/fork
-manual virgin p75
-exedy street disk (practically new)
-stock great condition oem pressure plate
-oem flywheel
*located in either savannah, GA or near jacksonville, FL.
Old Mar 3, 2006 | 12:12 AM
_Justus's Avatar
Default Re: WTB: All parts needed for Auto->5spd for 92-95 Ex Civic w/ b18b1 swap (not so civic)
Up Again! Anybody with these parts or the whole conversion PM either myself or Trock1029!
Old Mar 3, 2006 | 02:05 PM
I am USDM's Avatar
Default Re: WTB: All parts needed for Auto->5spd for 92-95 Ex Civic w/ b18b1 swap (tquick0910)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tquick0910 &raquo;</TD></TR><TR><TD CLASS="quote">Up Again! Anybody with these parts or the whole conversion PM either myself or Trock1029!</TD></TR></TABLE>
I did send a PM!
I guess ill send you one too...
Old Mar 14, 2006 | 10:10 PM
_Justus's Avatar
Default Re: WTB: All parts needed for Auto->5spd for 92-95 Ex Civic w/ b18b1 swap (I am USDM)
Back from the dead...still needing parts (B-series tranny,clutch,pressure plate,flywheel,throttle cable, and center console for 92-95 civic) Please PM if you have these parts!
Old Mar 15, 2006 | 04:38 AM
B A N N E D
i've got a flywheel if you're still needing one.
Old Mar 15, 2006 | 12:42 PM
[Ennis_D]'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by I am USDM &raquo;</TD></TR><TR><TD CLASS="quote">
I did send a PM!
I guess ill send you one too...</TD></TR></TABLE>
Pedals and cylinders worked like a CHARM! Thanks alot! Use me and tquick0910 as vouches anytime
Old Mar 15, 2006 | 12:47 PM
[Ennis_D]'s Avatar
IN DESPARATE NEED OF A GOOD WORKING CONDITION 5SPD LS TRANNY! PM EITHER MYSELF OR TQUICK0910! Thanks guys!
eg6sir-s's Avatar
i have the following for your car:
gsr clutch with pressure plate with under 32,xxx miles: $100shipped
jdm itr 98spec flywheel: $100shipped
gsr throttle cable for your swapped car: $20shipped
Old Mar 31, 2006 | 12:37 PM
_Justus's Avatar
Default Re: WTB: All parts needed for Auto->5spd for 92-95 Ex Civic w/ b18b1 swap (eg6sir-s)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tquick0910 &raquo;</TD></TR><TR><TD CLASS="quote">Back from the dead...still needing parts (B-series tranny,clutch,pressure plate,flywheel,throttle cable, and center console for 92-95 civic) Please PM if you have these parts! </TD></TR></TABLE> Still in desperate need of a good working condition b-series hydro 5-spd tranny, ls throttle cable, and center console (preferrably black) for 92-95 civic coupe. Please pm myself or Trock1029 if you have any of these parts. Thanks!
Old Apr 4, 2006 | 08:53 PM
[Ennis_D]'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tquick0910 &raquo;</TD></TR><TR><TD CLASS="quote"> Still in desperate need of a good working condition b-series hydro 5-spd tranny, ls throttle cable, and center console (preferrably black) for 92-95 civic coupe. Please pm myself or Trock1029 if you have any of these parts. Thanks!</TD></TR></TABLE>
In DIRE need of the TRANNY! We need someone local ASAP!
Old Apr 5, 2006 | 05:27 PM
[Ennis_D]'s Avatar
Nobody on this board has a good condition 5-spd hydro b-series tranny? Please help!
TheCrimsonGhost666
Mid-Atlantic (Sales)
Apr 15, 2011 10:29 AM
white4doorsi
12
Oct 27, 2006 10:25 PM
BigaCustoms
Nov 18, 2004 07:39 PM
RSXS421
May 16, 2004 08:32 AM
Mires
May 10, 2003 03:10 AM
