Wiring help 89 crx
Old Feb 27, 2006 | 01:59 PM
wood's Avatar
Default Wiring help 89 crx
Can anyone tell me where to find a wiring diagram for a 89crx si instrument cluster? Any clues where to search because i did try that. Have trouble finding where the wires to the small blue plug go. Is this the vss??? Please help!
If the blue plug isn't needed for the cluster as stated in one of the posts, then why is it there???? Can anyone tell me what it is for?
Modified by wood at 2:42 PM 2/28/2006
Old Feb 27, 2006 | 03:58 PM
BoostedEgHatchFl's Avatar
Default Re: Wiring help 89 crx (wood)
Bump b/c I need help with the same thing.
Old Feb 27, 2006 | 04:09 PM
ludesrv's Avatar
I beleive the VSS is in the tranny where the speedo cable goes in no? Ah maybe not.
Old Feb 27, 2006 | 04:19 PM
Super Chicken's Avatar
The little blue plug is the vss pulser that you seek, now whats your question in regard to this grasshopper?
BTW I couldn't find the diagram, but maybe someone else can.
Old Feb 27, 2006 | 04:32 PM
jlicrx's Avatar
these are for 91 - should be close
Old Feb 27, 2006 | 04:59 PM
wood's Avatar
Default Re: Wiring help 89 crx (jlicrx)
Thanks for the diagram jlicrx, can you tell me where it came from? Is it something I can download?
Old Feb 27, 2006 | 05:07 PM
wood's Avatar
Default Re: Wiring help 89 crx (Super Chicken)
One of my ? is how many different clusters were made? I continue to see that 88-89 or 90-91 are interchangeable ( plug and play ) but I have found this not to be the case. Flame me if you have nothing better to do (not you Super Chicken) but I have discovered at some expense that there are different cluster wiring harnesses for the same year. If this isn't true, why do some have vss and others don't?
Old Feb 27, 2006 | 05:54 PM
Bump why do some clusters have 3 plugs and some only have 2.
Old Feb 27, 2006 | 06:20 PM
wood's Avatar
Default Re: Wiring help 89 crx (BoostedEgHatchFl)
BUUUUMMMMPPPPP!
Old Feb 27, 2006 | 06:55 PM
BBBBBUUUUUUUMMMMMMMMPPPPPPPPP
Old Feb 28, 2006 | 04:40 AM
c0nspire's Avatar
blue plug isnt vss. 89 crx uses a mechanic vss. the blue plug u dont even need to hook up afaik, im not using it in multiple cars.
nd the 91 wiring is different from the 89
Old Feb 28, 2006 | 05:23 AM
Default Re: (c0nspire)
Thanks man
Old Feb 28, 2006 | 01:51 PM
wood's Avatar
ttt
Old Feb 28, 2006 | 02:30 PM
Bump anyone know why i don't have power to my gauge cluster lights and the heater controls????????
Old Feb 28, 2006 | 03:21 PM
wood's Avatar
BumP
Old Feb 28, 2006 | 03:36 PM
c0nspire's Avatar
check ur fuses
Old Feb 28, 2006 | 05:14 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoostedEgHatchFl &raquo;</TD></TR><TR><TD CLASS="quote">Bump anyone know why i don't have power to my gauge cluster lights and the heater controls????????</TD></TR></TABLE>
Check your dimmer switch make sure it has power and good ground
Old Feb 28, 2006 | 05:20 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by c0nspire &raquo;</TD></TR><TR><TD CLASS="quote">blue plug isnt vss. 89 crx uses a mechanic vss. the blue plug u dont even need to hook up afaik, im not using it in multiple cars.
nd the 91 wiring is different from the 89</TD></TR></TABLE>
Yes the wiring is different 88-89 to 90-91 but the blue plug is for the speed pulser
http://media.honda.co.uk/car/o...9.pdf
go there for the pulser location
Also try this, disconnect your speed sensor and drive around do you get a CEL? I did on my 88 Si and on my 89 DX with a PM6 ecu so it has to ge a speed signal from somewhere and my experience tells me its the little blue plug on the back of the speedo
Old Feb 28, 2006 | 06:03 PM
wood's Avatar
bump ttt
Old Feb 28, 2006 | 06:59 PM
Well I did check all my fuses and my dinner switch does not get power too it
Old Mar 1, 2006 | 05:07 PM
Go here fix this fuse
http://media.honda.co.uk/car/o...3.pdf
urquidezj
Jan 30, 2008 07:27 AM
LudeJdm
11
Jul 3, 2005 05:42 PM
VegaS10
May 26, 2005 07:04 PM
fastlude69
Apr 23, 2005 02:33 PM
