2000 Accord Brake lights out
A co-worker was behind me today and said my brake lights aren't working, sure enough they dont. I checked all the bulbs and they seem to be good, the rear lights and blinkers work. Is there a fuse or switch that could of went bad? Any help appreciated! Thanks
20amp fuse, usually paired with the horn. You'll find it in the Under-hood Fuse Panel. Refer to the fuse box cover for fuse assigned locations.
If the fuse checks out ok, then suspect the brake lamp switch (mounted on the Brake Pedal hanger brackets)
P
P
ATLHONDA
Mar 22, 2010 04:34 AM
