B Series Complete Turbo Kit For Sale. So CA, Ventura
As the title says I'm selling a B series turbo kit.
The manifold is a log style manifold. The manifold has been painted with a high temperature black paint and is designed to fit any B series motor. There are zero cracks or fractures on the manifold and is designed with a T3 flange.
The turbo itself is a very large T3/T4 turbo with a .50AR trim. There is very little shaft play and the fins are in great condition. The exhaust side of the turbo is a 5 bolt design. The turbo oil feed and oil return lines are stainless steel and included.
The custom downpipe is painted black with high temp paint and is 2.5" in diameter and is also a 5 bolt design.
The wastegate is a brand new, still in the box, never used, TIAL. The size is 38MM and features a .6lb spring which if memory serves me is about 8.82psi of boost. The turbo kit is sold without the wastegate.
The intercooler piping is 2" in diameter and is chromed. The chargepipe however is 2.5" and comes with a BLITZ blow off valve. All of the couplers and ring clamps are also included with the kit.
The intercooler itself is alumminum and efficient. The fins are in great shape as well as the tank welds, both along the seems and end tanks.
The turbo kit will also come with an inline fuel pump if you need it.
I believe that is everything, Ill make adjustments as needed. Email me with any questions you many have ... tunedek@gmail.com. You may PM however I'll recieve the email instantly on my blackberry. I will try and post pictures soon, until the kit is as described.
Please bump up.
---EDIT---
Right now I am setting the price at $1,100 for everything.
More on the specs on the turbo: T3/T04B .50AR
This kit is basically a Drag Gen 3 Kit with alot of larger parts.
Also forgot that this kit comes with the HKS turbo timer you see. Sweet!
Modified by tunedek at 8:21 PM 3/3/2006
Please bump up.
---EDIT---
all late night PMs replied retired for the day ...
as far as pictures its raining here pretty good right now ...
ill take some friday and post friday night - late at night
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tunedek »</TD></TR><TR><TD CLASS="quote">ttt 4 pic</TD></TR></TABLE>
Huee
May 19, 2005 08:43 PM
