Valve Cover Gasket Leaking?!
Old Feb 27, 2006 | 12:17 PM
midwesta's Avatar
Default Valve Cover Gasket Leaking?!
I think my valvecover is leaking from all four corners. Does anyone else seem to have this problem? It is the worse on the back of the engine on the drivers side right by the trans. I am hoping it is the VC gasket because thats only a 9 dollar part and a 10 min job. I think the VC gasket may have been put on wrong or could anything else be leaking in these areas? Here are some pics:
Old Feb 27, 2006 | 12:24 PM
Type X's Avatar
Default Re: Valve Cover Gasket Leaking?! (midwesta)
who did the install
did you replace the gasket?
you can't ask questions without providing all the info
your supposed to replace the gasket everytime u change the VC "supposedly"
when we did the VC on my ep3 it only had 300 miles so we figured it was ok
no leaks
Old Feb 27, 2006 | 12:28 PM
midwesta's Avatar
the VC gasket is rubber, so you dont need to change it everytime per say, just use honda bond correctly.
The VC has never been off.
Old Feb 27, 2006 | 02:02 PM
Red CiViC Hatch's Avatar
Default Re: (midwesta)
its a honda manufacturer defect. the vavle cover is bad y0.
how many miles are on the motor?
what kind is it?
is it the original motor?
this thread is pointless.
Old Feb 28, 2006 | 11:13 PM
midwesta's Avatar
Default Re: (Red CiViC Hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Red CiViC Hatch &raquo;</TD></TR><TR><TD CLASS="quote">its a honda manufacturer defect. the vavle cover is bad y0.
what kind is it?
this thread is pointless.</TD></TR></TABLE>
pointless, i guess here it was. on k20a.org i posted it and it turns out that most k20's have leaked from the factory, honda didnt do that well of a job with the Valve Cover gasket and hondabond.
most people have just resealed it and its fixed.
its a k20a, about 20k, and its in an EG.
Old Mar 1, 2006 | 02:53 AM
Type X's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by midwesta &raquo;</TD></TR><TR><TD CLASS="quote">
its a k20a, about 20k, and its in an EG.</TD></TR></TABLE>
i've owned 2 k20's
and 2 k24's..... none leaking and one we swapped the VC on
Old Mar 1, 2006 | 04:41 PM
midwesta's Avatar
mileage?
Old Mar 2, 2006 | 07:24 AM
mrDFWmechanic's Avatar
i have 2 friends with ep3's and they both leaked, just threw on a new gasket with some hondabond and called it a day
davidt1
Apr 4, 2012 06:44 AM
caliskier
Mar 22, 2009 04:45 PM
touandcim
13
Dec 29, 2007 09:46 AM
Mike1486
Sep 7, 2004 05:26 PM
RicedREX
Feb 9, 2003 09:31 AM
