question about timing.
Old Feb 27, 2006 | 09:58 AM
91 ZC hatchback's Avatar
Default question about timing.
when having to re-do your timing. do you have to spin the crank around a few times before lining it up with the cams?
or do you just spin it once till it gets to tdc?
Old Feb 27, 2006 | 10:06 AM
jlicrx's Avatar
Default Re: question about timing. (91 ZC hatchback)
don't turn it at all if you have the cams in and don't have a timing belt on it - with belt still on just turn it until arrows on cams are up and TDC mark on crank pulley is aligned
si0385.'s Avatar
your #1 cyl should have been at tdc when you took the timing belt off... the crank shouldint spin with out the timing belt on
Old Feb 27, 2006 | 10:15 AM
Default Re: (si0385.)
well crap. it wasnt, and the crank deff spins when the timing belt is off, but when i took it off i noticed my cams were one tooth off
and then i tried to fix that and thats when **** got effed up
Modified by 91 ZC hatchback at 11:42 AM 2/27/2006
Old Feb 27, 2006 | 10:41 AM
jlicrx's Avatar
Default Re: (91 ZC hatchback)
probably got lucky - the arrows on the cam gears are not up, correct?
Old Feb 27, 2006 | 10:43 AM
Default Re: (jlicrx)
as of right now everything is up. and it still wont start
but one of my friends told me you have to spin the crank around all the way a few times before you can set it on TDC to re-time it, so that why i asked before i got out there turning that ****
Modified by 91 ZC hatchback at 12:17 PM 2/27/2006
Old Feb 27, 2006 | 10:52 AM
jlicrx's Avatar
if everything is up, just set crank to TDC and then set cams - you don't have to turn it over - after you get cams aligned loosen the tensioner bolt, turn the crankshaft counterclockwise 1/4 turn and then tighten the tensioner bolt
f20beme
Apr 13, 2015 04:34 AM
alvaro328
Mar 17, 2015 12:17 PM
turboedsupe
Sep 19, 2008 04:32 PM
efyou
Jul 1, 2006 10:07 AM
98-ls
Mar 19, 2004 06:22 PM
