What do I need to hit 8600? (valvetrain)
Old Feb 27, 2006 | 12:45 AM
greasemonkee's Avatar
Default What do I need to hit 8600? (valvetrain)
I can't seem to find anyone with this setup...
gsr head
itr springs
ctr cams
Now seeing that gsr valves are heavier than the itr's, what will I have to do to make that safely hit 8600 with longevity in mind?
Springs and Titanium retainers both have cons. Which is the preferred way?
Old Feb 27, 2006 | 04:00 AM
Ed 341's Avatar
Default Re: What do I need to hit 8600? (greasemonkee)
What engine do you have? If its an ITR motor the max. hosepower is at 8000rpm, why do you need to go to 8600?
Old Feb 27, 2006 | 05:20 AM
Asahi's Avatar
Default Re: What do I need to hit 8600? (Ed 341)
While I don't disagree with asking the question there is some valuable powerband to be dropped into if you rev past peak. Not sure where 8600 specifically cam into play but if you make peak at 8000 then going past it slightly will put you in a more powerful area of the curve in the next gear.
I can't answer the original question but I doub't 8600 will hurt anything with the setup mentioned.
Old Feb 27, 2006 | 05:35 AM
Opie's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by greasemonkee &raquo;</TD></TR><TR><TD CLASS="quote">What do I need to hit 8600? </TD></TR></TABLE>
An ITR tach.
Old Feb 27, 2006 | 07:06 AM
itr1244's Avatar
Default Re: What do I need to hit 8600? (Opie)
all you need a *****
Old Feb 27, 2006 | 12:10 PM
Default Re: What do I need to hit 8600? (itr1244)
Ahhhh, let me explain...
GSR head with:
headwork
ctr cams
itr springs
cam gears
head milled .012" and 2 layer gasket to give 11.5-8ish cr??
itr short block
itr tranny
I actually haven't got the block yet. (summer project)
I felt there would still be some decent meat under the torque curve at that rpm, plus that was about the stock limit for that block and I want it to last a while.
I'm not much into reving the **** out of an engine, but I was under the impression that the higher cr would bump the powerband upwards significantly.
mesonerz
Apr 4, 2008 01:32 PM
yoorang
Sep 16, 2006 09:58 AM
Boostage
Dec 18, 2005 09:33 AM
xfrankx
Apr 25, 2005 06:07 PM
Richard.
Jan 8, 2004 12:57 PM
