New motor run like shit Brainstorm session
Allright guys looking for some ideas here...
90 Crx DX DOhc ZC srp pistons eagle rods new oem bearings arp headstuds oem head gasket
Single Cam turbo kit( being upgraded after motor breaks in)
SS AUTO frount mount and piping...
Turboedit pm6 with ostrich and basemap downloaded off of xenocrons site
Car wasnt starting for a while... firing order was wrong...
I just adjusted the valves but i need to redue them because i didnt do it right...
Car starts and idles fine... it revs up peppy also but as soon as i start to try and drive it it bogs down and runs like ****...
Im making a boost leak tester to test for any leaks ( i think i have a vaccum leak)
and im hoping thats it... Any other suggestions would be helpful.
It doesnt hurt to get ideas from people....
Good compression
Thanks guys
Good compression
Thanks guys
check ur tps, cam timing, we need more info sounds like you built a whole engine from scratch so there are many things that can go wrong. hell maybe your rings arent broken in. any check engine lights? smoke? wierd noises?
yeah i have triple checked cam timing...no cel and no smoke...just hooked up vaccum gauge and its at 10 HG 18-19 is normal in my are an i sprayed some h20 around the manifold and idle stabalize so im going to tighten my bolts see if it helps
hatchinprogress
Feb 17, 2006 09:18 AM
