seats in a 5th gen
Old Feb 26, 2006 | 04:45 PM
Chris.'s Avatar
Honda-Tech Order of Merit
Default seats in a 5th gen
my friend just bought a set of gsr leather front seats and he was wondering if they will fit in his 95 accord coupe. if so, what does he need to do in order for them to fit?
thanks in advance
Old Feb 26, 2006 | 08:14 PM
lamsv's Avatar
I don't think they are going to directly bolt into your car. But, try that first just in case. More than likely though...
You need to unbolt the seat brackets/sliders from the integra seats. Do the same with your Accord seat brackets/sliders. See how close the Accord brackets align to the Integra brackets. Here is where it gets tricky (and custom). I doubt that the brackets will line up to the holes, and, I would venture that the width between the mounting holes is off. Why does this matter? If you don't mount the brackest at the same width as the mounting hole on your chassis...they won't fit. So, have somebody weld up tabs on the Accord brackets/sliders so that you can mount the Integra seat to them, and keep the Accord brackets at the correct width to mount them to the chassis.
Just make sure to sure to measure everything up carefully, and it should work perfectly.
Old Feb 26, 2006 | 09:49 PM
Chris.'s Avatar
Default Re: (lamsv)
thanks
Torino117
Aug 2, 2011 04:16 PM
89sparks
Oct 9, 2007 09:50 AM
JdMotor26
Dec 28, 2004 01:45 PM
Whatever
Oct 8, 2003 09:28 PM
darkknightwong
Feb 27, 2002 11:17 AM
