S2K antenna kit
Old Mar 29, 2002 | 05:30 AM
RStoR's Avatar
Default S2K antenna kit
If your interested in one..... https://honda-tech.com/zerothread?id=154069
[Modified by RStoR, 9:33 AM 3/29/2002]
Old Mar 29, 2002 | 05:36 AM
Mike M's Avatar
Founding Member
Default Re: S2K antenna kit (RStoR)
Chris
Old Mar 29, 2002 | 05:41 AM
Turtle's Avatar
I heard that the reception is greatly reduced when you change out to an S2K antenna. Can you tell me about this....(I'm not trying to post ***** - just wanted to know if there would be a difference).
Old Mar 29, 2002 | 05:43 AM
BoM's Avatar
BoM
Default Re: S2K antenna kit (401-2001)
better reception for me
Old Mar 29, 2002 | 06:02 AM
RStoR's Avatar
I truly think it has to due with your location. I've sold 60+ kits throughout the US and Canada so I've gotten a lot of feedback. It seems if you live in a metropolitian area, your reception will go unchanged. If you live in a smaller area where towers may not be as close, then reception may go down. Several boosters/additional antennas have been tried, but nothing has successfully worked yet. Hope that helps!
Old Mar 29, 2002 | 06:07 AM
Turtle's Avatar
Perfectly stated; thanks for your complete honesty! NICE to see that. I really do think that the look is MUCH cleaner. How much work is involved in getting it installed?
Old Mar 29, 2002 | 06:09 AM
BryanSprinkel's Avatar
OT: Man, that car is ulgy!! Bronze volks, yellow car? Man, who would do such a thing.
Bryan
Old Mar 29, 2002 | 06:40 AM
01ITR#700's Avatar
Default Re: S2K antenna kit (BryanSprinkel)
I ordered one a while back from Chris, took a little while due to the Holidays but good service. I haven't installed mine yet, I'm going to wait untill I install my OEM rear under spoiler and pull my wing off for a full "*** conversion"
Old Mar 29, 2002 | 07:07 AM
adam's Avatar
Default Re: S2K antenna kit (01ITR#700)
and how much is the S2K mast?
Old Mar 29, 2002 | 07:21 AM
RStoR's Avatar
Default Re: S2K antenna kit (adam)
The mast usually goes for $20-22 from Honda. Email Mike K and see if he can get you a good price.
PS: Acura MDX antenna is the same as S2K
[Modified by RStoR, 11:21 AM 3/29/2002]
Old Mar 29, 2002 | 07:29 AM
gina's Avatar
New User
Hmmm I like this look, how difficult is it to install?
Old Mar 29, 2002 | 07:36 AM
RStoR's Avatar
Default Re: S2K antenna kit (00 Type R Chick)
Install time takes 20-60 minutes depending on your level of mechanical skill. Very simple install with basic tools.
Old Mar 29, 2002 | 07:48 AM
WalkmanX's Avatar
yeah, how hard is it to remove the existing motor? I'm definitely interested if its not hard to do!
Old Mar 29, 2002 | 08:59 AM
BlkITR #1404's Avatar
Default Re: S2K antenna kit (WalkmanX)
that look absolutely great, i have one laying in my cabinent, but i haven't tried to intsall it yet
Old Mar 29, 2002 | 09:05 AM
BSQ's Avatar
BSQ
You can get the S2000 mast at http://www.http://www.hondaautomotiveparts.com for $13.95 . Here is the link: http://www.hondaautomotiveparts.com/...NTENNA-SPEAKER
Here is the part number: 39151-S2H-E01
[Modified by BSQ, 1:08 PM 3/29/2002]
Old Mar 29, 2002 | 12:04 PM
RStoR's Avatar
Default Re: S2K antenna kit (BSQ)
BSQ...thanks for the tip!
The install is very straight forward. All you have to do is remove the rear plastic hach covers to expose the motor. The motor is held in my that silver ring on the outside of the antenna base and 2 bolts inside. Unplug the OE coax cable and out it comes. You have to adjust the conversion kit a bit for a snug fit. Very simple conversion even for the novice mechanic.
Old Mar 29, 2002 | 12:13 PM
05 600RR's Avatar
I think I'm going to have to jump all over that, I have had the mast since x-mas but have been too lazy to make a kit to install it.
Old Mar 29, 2002 | 12:15 PM
killingtime's Avatar
Default Re: S2K antenna kit (itr 01-0492)
Also remember that the Insight antenna will fit on the S2000 mount.
Its 14" - reception should be a bit better.
Hope this helps,
Demian
Old Mar 29, 2002 | 12:24 PM
B2FiNiTY's Avatar
Default Re: S2K antenna kit (killingtime)
Very interesting...
Old Mar 29, 2002 | 12:32 PM
RStoR's Avatar
killingtime...thanks for the tip on the Insight antenna.
Old Mar 29, 2002 | 01:36 PM
hooptie157's Avatar
Bryan
do you also think the Mugen wheels are ugly on a yellow ITR?????
Old Mar 29, 2002 | 01:40 PM
RStoR's Avatar
Default Re: S2K antenna kit (hooptie157)
Bryan
He owns the extra same car...PY ITR with bronze Volks. Justa joke!
Old Mar 29, 2002 | 02:10 PM
NW94RS
Guest
Posts: n/a
that looks funny not bad just diffrent
Old Mar 29, 2002 | 02:57 PM
Calavera's Avatar
Default Re: S2K antenna kit (dc-2R)
How does this insight antenna look like, I never paid attention to the antenna whenever I see an insight on the streets.
Tools required, How-To instructions on the S2K antenna install: http://www.bseries.net/html/garage/s2kantenna.php
sorry chris, my bad.
[Modified by Calavera, 6:22 PM 3/29/2002]
Old Mar 29, 2002 | 04:10 PM
RStoR's Avatar
Default Re: S2K antenna kit (Calavera)
Calavera~
thanks
[Modified by RStoR, 9:57 PM 3/29/2002]
