Anyone using F22A accesories on H22A swap?
50% done with my swap i just wanted to know if someone is using all the accesories from an f22a like P/S...altenator...A/C...and brackets. I just want to make sure that I will have proper fitment. If anyone has any pictures of their engine bay with f22a accesories in it that would be perfect. Thanks.
The f22 alternator will bolt on the h22 bracket, just swap pulleys.
The f22 ac comp will bolt on the h22 bracket.
The ps pump is different, use an h22 one.
If i use the h22a p/s pump will i have a problem with it being used with the f22a crank pully? Guess i need to get these damn brackets...i only have the bare block thats why im asking.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ShinobiLude »</TD></TR><TR><TD CLASS="quote">50% done with my swap i just wanted to know if someone is using all the accesories from an f22a like P/S...altenator...A/C...and brackets. I just want to make sure that I will have proper fitment. If anyone has any pictures of their engine bay with f22a accesories in it that would be perfect. Thanks. </TD></TR></TABLE>
i just recently ditched a/c so when i did my f22 h222 hybrid i just kept the f22 alt and used a belt that would fit the rib count
I've got an H22 in my Acura CL which had an F22. I'm using the H22 p/s pump and the F22 pump line, it doesn't fit properly but my dad made it fit. Here's a pic.
rival12
Mar 19, 2004 05:44 PM
