ENJO MOUNTS?
Old Feb 26, 2006 | 08:40 AM
saikouEF8's Avatar
Default ENJO MOUNTS?
i just bought another crx with an ls motor in it... theres ENJO RACING mounts in the car already....HOWEVER i need to buy a linkage for the car.... should i keep the Enjo stuff and get an enjo linkage or get rid of the mounts and go HASPORT all the way? does anyone have experience wth enjo racing mounts and linkages? anyone know the real difference between the way each product is welded and if that matters??? ANY info would be appreciated...
Old Feb 26, 2006 | 08:48 AM
godruler's Avatar
Default Re: ENJO MOUNTS? (saikouEF8)
if you already have mounts holding the motor in and the motor is not falling out i don't see why you would buy other ones. thats like throwing away $400 for hasports, if they are serving there purpose i would'nt even touch it, put the money else where. why don't you make your own linkage, get some Da linkage and shorten it to fit, or even weld in some threaded rod, make it adjustable.
Old Feb 26, 2006 | 08:55 AM
saikouEF8's Avatar
well im just curious because of engine placement... th engine loks straignt in the car... so i guess is ok...the problem is hasport has such a good rep and the linkage is a lot cheaper than the enjo one (almost double the price).. but oh well im thinking of staying with the enjo mounts and buying the linkage anyway... illpost some pics later and do a lil write up.
palisoc05
May 24, 2008 07:42 AM
91EF_Si
Sep 27, 2007 07:09 PM
jarel
Dec 15, 2004 07:07 AM
B16CRXT
Nov 27, 2004 12:21 PM
SteveeeO
17
Jan 5, 2003 03:07 PM
