Please help: transmission related...
Old Feb 26, 2006 | 06:45 AM
felmans's Avatar
Default Please help: transmission related...
Hey Guys, I'm a newbie in this forum...
This is what's been happening...I have a 1997 Honda Accord 4cyl automatic.
A feew days ago I was driving down the road and started having this problem:
when I hit the gas, the car wuold cut the rpms at around 3,000, like if ou leave the gear in neutral, but it was in gear. and the car wouldn't go...It would change gears slowly or not change at all. The Check Engine Light came on:
P1361
P0740
P0715
these are the 3 codes...I know the first one is the TDC sensor..
Here's my question: could the TDC sensor have caused this?
the car has 120K miles...the tranny's fluid is fine.
then I took it to a mechanic and he was doing a diagnostic and touched something like a sensor or something and then the car would only go on reverse and not foward anymore. You could leave it in gear and give it full gas and it won't move.
could he have touched something that turned the tranny down?
CAn anyone Help me please!!!
Thank You guys
Old Feb 26, 2006 | 07:10 AM
felmans's Avatar
anyone please???
Old Feb 26, 2006 | 08:16 AM
P_Adams's Avatar
Default Re: Please help: transmission related... (felmans)
P1361 = TDC Sensor Intermittant interuption (Engine Management)
P0740 = Torque Converter Ckutch Circuit interuption (Engine Management)
P0715 = Input/Turbine speed sensor circuit malfunction (Engine Management)
I suspect all wiring related. More than likely all three are routed through a single multi-connector. I'd take a serious look at
"took it to a mechanic and he was doing a diagnostic and touched something like a sensor or something and then the car would only go" what he was touching when this occured. Look for anything out of the ordinary, chaffed or pinched wiring, partial connectors etc.
The system is telling us it's an intermittant problem with the Engine Management System.
If it were Trans related, the D4 lamp would be flashing (instead of the "service engine soon" lamp)
Most likely the intermittant condition is throwing the EMS into "Fail-safe (Limp home) mode; limiting engine rpm's etc.
P
Old Feb 26, 2006 | 04:40 PM
felmans's Avatar
Default Re: Please help: transmission related... (P_Adams)
tnx bud:
question...how couold I fix that intermittant condition? could it be wireing? how about the sensor itself? which one is it?
just checked all wires and plugs and they all seem okay...
what should my next step be?
tnx
Old Feb 26, 2006 | 05:25 PM
YeuEmMaiMai's Avatar
most obvious solution would be replace sensor with a new one. Intermittent sensor problems are a PITA to diag cause you have to be having the problem when you decide to troubleshoot.
Old Feb 26, 2006 | 05:38 PM
jfish's Avatar
I think your trans is shot
Foxracingfreak
Transmission & Drivetrain
Oct 18, 2015 03:40 AM
brownje000
Jul 16, 2008 09:57 AM
coopdawg1979
Mar 6, 2007 07:02 PM
Nemesis519
Jul 29, 2004 05:44 PM
