((((having problems w/ car running rich and hesitating))))
Old Feb 26, 2006 | 04:36 AM
89sicivic's Avatar
Default ((((having problems w/ car running rich and hesitating))))
just got done w/ a head swap put a z6 head onto my zc sohc block...after riding it around and the car getting impounded for a few days i finally get it back and start it up from the impound and go to drive it home and the car just hesitates like no other it feels like im downshifting and then steppin on the gas then when i come to stop and take off my car wouldn't rev past 2.5-3...then i finally get it home and took spark plugs out and all 4 were fouled out and smelled of gas anybody have a idea on what could cause the car to hesitate so badly.....i believe my coil pack is going back i have hardly no spark....also what fuel rail should i use should i stick w/ the z6 one or should i put the zc one back on...any help would be appreciated
Old Feb 26, 2006 | 12:52 PM
89sicivic's Avatar
anybody w/ some help on this matter?
Old Feb 27, 2006 | 12:24 PM
i64X's Avatar
Default Re: (89sicivic)
Check timing with a light. You probably have the cam timing off by a tooth or two. Happened to me.
Old Mar 3, 2006 | 09:17 PM
89sicivic's Avatar
anybody else help me w/ this
Old Mar 3, 2006 | 09:25 PM
crxdriver89's Avatar
are your vacuum lines hooked up right?? could have switched a couple during the swap, might cause the hesatation.
Old Mar 3, 2006 | 09:33 PM
89sicivic's Avatar
yeah i got the vacuum line tooken care of the hesitation was really bad...car would instantly drop rpms and tires would screech then rpms would eventually go up then when i come to complete stop the car wouldn't rev past 3k
Old Mar 4, 2006 | 09:50 AM
so you got it fixed?? you were using past tense on describing it, so im assuming it was the vac. lines??
salvador96
Jul 23, 2014 08:50 PM
spens 91 Ef
Sep 15, 2009 02:49 PM
nexgen91
Oct 26, 2006 01:59 PM
89sicivic
May 14, 2006 10:45 PM
SOHCrx
Apr 17, 2004 04:51 PM
