98 early rev limit and check engine
Old Feb 25, 2006 | 11:06 PM
SilverGSX90's Avatar
Default 98 early rev limit and check engine
Im having some problems with my lude... i go wot on the car and when i get to around 6500 rpms the cars hits a rev limitor and turns my check engine light on. i checked it and a cyliner two misfire came out? I reset it it was good for a few pulls then same thing? also hppening in 3rd gear? what could this be? can it be a certain sensor?spark plug? wire? distibutor? any help .. thanks
Old Feb 26, 2006 | 06:56 AM
ludecz's Avatar
Default Re: 98 early rev limit and check engine (SilverGSX90)
from what you're saying looks like spark plug, wire or the cap, if some sensor is failing it would most likely show up as a code.
Old Feb 26, 2006 | 11:26 AM
david1686's Avatar
i have a 98 prelude base and i have that same problem. i also eat about a quart of oil every 200 miles. and i am smokeing alot especially in v tec. need help .thanks
Old Feb 27, 2006 | 04:25 AM
david1686's Avatar
Default Re: 98 early rev limit and check engine (david1686)
has this happen to anyone?
Old Mar 2, 2006 | 09:54 AM
david1686's Avatar
bump
redlinez_r_us
Sep 23, 2008 09:27 AM
DBail
Sep 15, 2008 05:09 PM
integraty95
Oct 9, 2007 04:38 PM
fineAccord
Feb 25, 2006 12:06 PM
aktc167
Sep 28, 2004 11:04 AM
