Suspension & Brakes Theory, alignment, spring rates....
Ground Control question
Old Feb 25, 2006 | 07:17 PM
AccordCD5's Avatar
Default Ground Control question
I'm looking to buy a set of ground control custom rate sleeves for my 96 Accord. As of now I my setup is H&R's and KYB AGX. I plan to continue using my AGX's but later I will be upgrading to Koni yellows. I want to get some recomendations for a custom spring rate. I will be using the car on the street. some auto x and in the near future some beginer road racing. any help will be great, thanks
Old Feb 25, 2006 | 07:43 PM
coot_er's Avatar
Default Re: Ground Control question (AccordCD5)
i could be wrong but i don't think that the springs will work on both the koni's and the kyb's. if you get illuminas instead of koni then it would work. but the koni is a size of its own
Old Feb 25, 2006 | 07:58 PM
.RJ's Avatar
.RJ
Default Re: Ground Control question (coot_er)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by coot_er &raquo;</TD></TR><TR><TD CLASS="quote">i could be wrong but i don't think that the springs will work on both the koni's and the kyb's. if you get illuminas instead of koni then it would work. but the koni is a size of its own</TD></TR></TABLE>
ground controls work just fine on konis. you just need the correct adapter ring on the bottom of the sleeve.
Old Feb 25, 2006 | 08:23 PM
AutoXer's Avatar
Default Re: Ground Control question (.RJ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .RJ &raquo;</TD></TR><TR><TD CLASS="quote">
ground controls work just fine on konis. you just need the correct adapter ring on the bottom of the sleeve.</TD></TR></TABLE>
Can you just add the adapter ring from the AGX type to the GC type?
I looked into it, as I was going to run GC with my AGXs until I could afford the Koni upgrade; and had been told that it wouldn't work, but I never got any concrete evidence. I just ordered the combo, due to the springrates I wanted to run anyway.
Old Feb 25, 2006 | 08:47 PM
AccordCD5's Avatar
well lets just say I am going to stick with my AGXs what would be a suitable spring rate to run for my setup? I want something suitable for running auto-x
Old Feb 27, 2006 | 03:19 PM
AccordCD5's Avatar
ttt
Old Feb 27, 2006 | 03:44 PM
AutoXer's Avatar
What's wrong with just running what you have until you get the Konis? You can use your H&R on the Konis until you get the GCs.
I ran almost two seasons on Ebach Pro-Kits, and tropied a few times, and the H&Rs are more agressive rates than that. Mods don't make you faster, seat time does.
Konis with H&R would be a much better setup than AGX and GC; because the AGX won't be able to dampen the higher GC springrate.
Old Feb 27, 2006 | 04:26 PM
AccordCD5's Avatar
Default Re: Ground Control question (AutoXer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AutoXer &raquo;</TD></TR><TR><TD CLASS="quote">Konis with H&R would be a much better setup than AGX and GC; because the AGX won't be able to dampen the higher GC springrate.</TD></TR></TABLE>
You do make a great point and touched on some vaild info I was searching for. I guess I am thinking of my setup from more of an apperance stand point. I am hunting down a set of 16x7 wheels, I feel my OEM 15" and 195x60s are just not going to cut it on my rolly-polly mobile. Since I will upgrade my wheel/tire size to 215x45x16 I am afraid what kind of wheel gap I would encounter. For now I will wait untill I can afford all the componets at once.
GC's, koni yellow's, camber correction, Suspension Tech. sway bar kit, and upgrade bushings.
**how could I improve this setup( I am an extreme nood when It comes to this stuff)
Old Feb 27, 2006 | 05:27 PM
JDMISACULT2's Avatar
mmm seat time is always good however at autox you hardly get any!!! its the worst
Old Mar 12, 2006 | 05:12 PM
AccordCD5's Avatar
up
dxlol
Suspension & Brakes
Oct 21, 2010 02:09 PM
gabstar
Suspension & Brakes
Sep 19, 2006 01:34 PM
gabstar
Sep 19, 2006 12:13 PM
Itr001
Nov 1, 2005 10:28 AM
slowacura
Dec 13, 2003 11:25 PM
