2000 si seats in 91 dx
Looking into buying these seats and searched to see if they would fit.
People are saying that they sit too high, but dont say if they use the 2000 pan or the crx pan.
Im wondering if using the crx pan will make them sit at a better level. If anyone has experiance with these seats, please shed some light.
The seat pans on newer cars are far different than our older cars. So most likely they will not work unless you severly modify the seat pan, or find a way to attach the stock crx/civic rails to the seat(which is not easy on the newer seats). So to anwer your question, don't buy them! Look for seats that are older(88-99), and get pics of the bottom of your prospective seats to see if the seats match your rail design of 4 bolts. That way in the worst case you could put you stock rails on the seats or make a set of rails that will fit. Goodluck
this thread caught my attention because i have a 90 std that i'm building and I have some 00 Si seats sitting in my room. anyway, i found a set of rails out of a 89-91 hatch and compared the two. it's not a direct plug and play, but if you're good w/ a measuring tape and drill, you can get it lined up pretty easily. Hopefully mine will start going together around spring break and i'll be sure to take pics of the seat install if anyone is interested. also, if there's enough interest i'll do a write-up.
PS - if there is a write-up floating around, let me know so mine isn't wasted
inh
May 10, 2008 08:42 PM
Just2Fast
Jul 6, 2006 09:00 AM
