F22/H23 crank and rods in a 93 JDM H22 block, which F22/H23 to use???Build up help!
Old Feb 25, 2006 | 03:43 PM
ExplicitSpeed360's Avatar
Banned.
Default F22/H23 crank and rods in a 93 JDM H22 block, which F22/H23 to use???Build up help!
Hello I spun a rod bearing so time for a new build up. I have some questions. TIA
Will any F22 crank and rods work and are they all 50mm mains and 95mm stroke?
H23A1 usdm 92-95 prelude will work? 50mm mains?
93 JDM H22A 50mm mains?
Can I get away with re ringing the JDM H22 pistons with no hone? how?
The cheapest F22 is obviously the one in the 90-93 accords F22A1-6
The H23 and F22 are they free floating or pressed in?
Build up:
F22/H23 crank and rods balanced
honda bearings
honda piston re rings on the JDM H22
compression should be right around 11.5-1 with 30k mill of the head
This is going in my daily driver so what I have been told from people is that if I safe guard my self and balance everything and use honda bearings and rings I should have a decent life with the engine with a redline of 7500 and no more. Also debating to shotpen the rods for added support but at the same time tryin to keep the cost down. Any help or advice would be great TIA-John
95accordsir
May 22, 2008 10:07 AM
zo4000
May 26, 2007 08:25 AM
93ludesitec
Aug 16, 2006 08:26 PM
ExplicitSpeed360
15
Jul 25, 2006 01:14 PM
ExplicitSpeed360
Mar 2, 2006 06:02 PM
