Suspension & Brakes Theory, alignment, spring rates....
Eg spring rates
Old Feb 25, 2006 | 03:07 PM
2DoorBandit's Avatar
Default Eg spring rates
hey guys i was wondering what are stock rates for and eg civic i gonna order ground controls and koni yells and i wanna get something stiifer then stock also if needed car is going to be lowered to get rid of wheel gap and it will see the track occausanlly i was thinkin 400f and 350 rear or 450 front and 350 rear also this is my daily driver ....whate rates do u guys think are good
thanks
Old Feb 25, 2006 | 04:41 PM
chrisw85's Avatar
off the shelf GC are 380F/280R, which are quite fine for daily driven. If you want a little stiffer but still quite streetable, 400F 400R is a good start. Then you can pick up an extra set of springs for track say a set of 550+ for the rear. Get the springs to be 8" and it'll be easy to swap front to rear to try out diff things.
edit: stock civic eg is about 160-180 front and about 100 in the rear...someone correct me if im wrong. ITR is at about 220F 220R.
Old Feb 25, 2006 | 04:55 PM
Voyage34's Avatar
Default Re: (chrisw85)
Ive never seen a definitive set of rate numbers for an eg, but fwiw ej8(ek) are 165/80. I'd assume the eg wuold be about the same or a little lighter because the cars themselves just slightly lighter.
ITR are 250/250
makelove2hondas
Suspension & Brakes
Nov 14, 2005 09:41 AM
HUBB
Suspension & Brakes
Sep 11, 2005 07:36 PM
pgpunkguy
Suspension & Brakes
Apr 22, 2005 05:09 PM
CivicESi
Jan 4, 2005 05:54 PM
eg6beater
Jul 31, 2004 09:51 AM
