Need help on B16A1 Swap
Hello, I am thinking of buying a EDM B16A1 from a EE8 CRX. Is $952 good for an engine w/ 110000 miles, including tranny, dizzy, manifolds, wiring harness, and ecu? It needs the oil pan seal changed. I have been told to replace the camshaft seal and crankshaft seal, also the water pump and the timing belt. I am getting a set of mounts and axels, and was wondering if I would need new hubs or anything else that I would need. Do I need a shift linkage? What model/year parts would I use from a US Spec civic, and Also is the vtec solinoid on the block? Thanks
Modified by nexgen91 at 8:15 PM 2/25/2006
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nexgen91 »</TD></TR><TR><TD CLASS="quote">Hello, I am thinking of buying a EDM B16A1 from a EE8 CRX. Is $952 good for an engine w/ 110000 miles, including tranny, dizzy, manifolds, wiring harness, and ecu? It needs the oil pan seal changed. I have been told to replace the camshaft seal and crankshaft seal, also the water pump and the timing belt. I am getting a set of mounts and axels, and was wondering if I would need new hubs or anything else that I would need. Do I need a shift linkage? What model/year parts would I use from a US Spec civic, and Also is the vtec solinoid on the block? Thanks
Modified by nexgen91 at 8:15 PM 2/25/2006</TD></TR></TABLE>
What model do you have? What current motor is in the engine compartment?
your paying way too much first of all, why dont u get order a jdm obd1 b16 for 1800 from an engine importer?
vtec soliniod is on the side of the head in front of the dizzy, the camshaft seal is behind the vtec soliniod
pending your year and model, then we can tell you what you need,
i dont kno how i just made 2 posts??
I am in europe, it would be 600 to ship an engine here from the states, and 1800 from an importer would be 2400 which I cannot afford at the current time, that is why I dont buy one. I would if I could get one imported here for a reasonable price, but I cant. I have a 91 Civic DX Hatch with MPFI conversion already done. Thanks
its kinda hard to say if thats a good deal motors might be more over there but i would assume they would be less for a b16 over there because crx's came with 16's in europe and not in america... but i wouldint pay that much for a b16
That is about the going rate here, I actually thought it was decent, because if I got one from Hmotors.com hten it would be like $1200 plus $600 to get it shipped here, cant afford that.
civic-steve-94
13
May 26, 2011 08:26 PM
KooK
Jun 10, 2003 09:47 PM
