random idle (videos)
Old Feb 25, 2006 | 08:01 AM
efyou's Avatar
Default random idle (videos)
what the hell is goin on?...movies are off my fone...u need quiktime to view em i believe
http://www.zippyvideos.com/4512534293961986/a/
http://www.zippyvideos.com/7717996193962026/a2/
Old Feb 25, 2006 | 10:37 AM
efyou's Avatar
Default Re: random idle (efyou)
bump
Old Feb 25, 2006 | 11:08 AM
ck123's Avatar
me guessing oil in spark plugs
replaced distrubutor and all 4 plugs and problem went away. Also had to replace valve gasket
Old Feb 25, 2006 | 11:56 AM
3s0n3's Avatar
weird uh..... perhaps a vaccume issue? or sensor ..... keep searching cause ive seen that on other cars and smaller engines
Old Feb 25, 2006 | 07:31 PM
theinfamouskonrad's Avatar
Default Re: (ESONE S1)
check all your vacuum lines. Are you throwing any cels? what ecu are you using?
Old Feb 26, 2006 | 01:53 PM
efyou's Avatar
Default Re: (theinfamouskonrad)
jus replaced all the plugs and wires and distributor...using a pr4...no cels...might be something to do with oil in tha plugs becuz the idle isnt smooth as it was when i jus replaced the plugs...i know the headgasket is shot, and only sensor i havent replaced is the tps.
Old Feb 27, 2006 | 06:24 PM
efyou's Avatar
Default Re: (efyou)
bump...when i push the clutch in from goin some where itll sit at like 1700 and then as i come to a stop itll raise to about 2k...if i sit for about 5 seconds itll drop to normal idle...then stumble to about 900 and then bak up to normal which is about 1100...doesnt make sense
Old Feb 27, 2006 | 07:56 PM
ZCRex91's Avatar
Default Re: (efyou)
Just fixed this problem in my CRX
Sometimes it's the idle/air controller that you just need to spray the carb cleaner in to clean it
But most of the time it's the thermal valve, the little flat head screw/bolt on top of the throttle body next to the idle adjustment and junk...
I guess it happens, more often if you rail yoru car some..
Hope that works!
Old Mar 1, 2006 | 08:03 AM
efyou's Avatar
Default Re: (ZCRex91)
well...i believe my ecu is shot...i put in a pr3 from a previous b16 swap and the only thing it does is jus doesnt idle up when cold, but no stumbling...powers kinda different becuz of the diff motors but other than that i think my pr4 is shot.
boost4life1
May 15, 2012 08:52 PM
Sticky2K
Mar 31, 2010 08:02 AM
SuM Honda
Jan 1, 2010 07:29 PM
jdmekrobot
Dec 7, 2007 12:33 PM
92eg6lsvtec
Sep 19, 2004 08:19 PM
