1994-1995 accord red/clear tails
does anyone know where to pick these up , I am certainly never going to go and get altezza's no matter even if i dont find these rare taillights. , does anyone know where? I searched ebay , everywhere. cant find them
If you're looking for stock replacements
TAS Auto Parts
1AAuto Parts
If you're looking for Aftermarket
Racerwheel.com is pretty good for seeing what's out there
P
TAS Auto Parts
1AAuto Parts
P
to make your stocks cleared like this:
you'll have to remove the plastic amber filter. the easiest way to do that is just use a set of needle nose pliers, break it into small pieces, and remove. half red half clear tails arent made anymore and looked like crap when they were out.
Modified by street_accord94 at 4:43 AM 2/26/2006
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eagle16nam »</TD></TR><TR><TD CLASS="quote">why did they look like crap? I think they looked really good? does anyone know where I can find half red half clear tails anymore?</TD></TR></TABLE>
because you need yellow blinkers. just remove the amber part, and use an amber bulb.
the only place you'll find red/clears is egay rarely...DOT mandated a recall on them since the clear reflector didnt meet spec. also they just didnt flow well with the rest of the rear.
I did my set by cutting around the back of the taillight with a razor blade. You only have to cut about a 2x1 inch square around where the orange piece is. Then all you do is pull the piece out and then the orange out. Very easy to do. If you break the piece out with pliers you can damage the inside by scratching all of the silver off. Once you remove the 2x1 inch piece just put superglue on it to hold it in place and the run some silicon around the cut. Took me about 15 mins.
GOLDBERG
Jul 9, 2006 03:05 PM
