EGR Valve help.
Old Feb 24, 2006 | 06:40 PM
uofa's Avatar
Default EGR Valve help.
This is a lame question, but does anyone know offhand what tools would be needed to replace an EGR valve on a 2000 Accord EX?
Edit: The reason why I am asking is I don't have my car here to actually go look, nor the right tools, so I have to let my dad know what tools he needs to get.
Old Feb 24, 2006 | 07:04 PM
NAiL05's Avatar
I would say a wrench but then i also dont have a V6 motor around me. Your best bet is to pick your *** up and go look. Why are you replacing it? Honda had a TSB on sixth gen EGR's so see if they will replace it for you.
Old Feb 24, 2006 | 07:07 PM
uofa's Avatar
Default Re: (NAiL05)
I don't have my car here...notice the edit.
The dealership would have replaced it with the kit for free if my Accord had under 80,000 miles. Unfortunately, mine isn't.
However, they do owe me one. I've already experienced the shitty 6th gen tranny, and had to have mine replaced. The first one they got from Honda was dead, so it took me almost a month to get my car back.
Old Feb 24, 2006 | 07:11 PM
NAiL05's Avatar
My bad. Well i think you need a wrench to pull it off. Its prob held on by 2 bolts. i dont have a v6 to go look at as i mentioned but a wrench should be able to get the EGR off if not a socket.
Old Feb 24, 2006 | 07:25 PM
BLKFLSH's Avatar
I don't see where he said V6? He just said EX.
Old Feb 24, 2006 | 10:25 PM
YeuEmMaiMai's Avatar
Default Re: (BLKFLSH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BLKFLSH &raquo;</TD></TR><TR><TD CLASS="quote">I don't see where he said V6? He just said EX.</TD></TR></TABLE>
I think he read the shitty trans part and V6 have 80K on warranty for EGR I got my EGR done at 90K cause I just bought the car and the dealer gave me a break.
Old Feb 25, 2006 | 04:04 AM
Ross 2.0's Avatar
In a Junkyard near you.
You need a 6pt 12mm 3/8 socket a 6 inch extension and a short ratchet (to keep from breaking the studs). After you get it off be sure the old gasket is taken off.
HOWEVER you need to remove the plentum (the intake manifold) to check the EGR port. Take the plastic covers off of the top of the engine (you need to do this to replace the EGR too). Then you need to remove 8 or so more 12mm bolts. After those are off pick up on it to seperate it from the studs. then prop it up on the left side with a long screwdriver. Put a few towels over the ports going into the engine.
Then if you look at the bottom side of the plentum you will see the other side of the ports then near the throttle body you will see a smaller circular hole. Stick a small screwdriver through there and see if it goes the whole way through (good chance it won't) If not it's clogged with carbon.
This is the point where your dealer was going to install (or replace) the "pipe kit" .
We have a special drill bit to drill out the carbon and widen the hole to then install the new pipe.
You can try to clean it out yourself but it won't last unless you install or replace the EGR pipe.
After you resolve that issue you need compressed air to blow through the corresponding hole on the engine side of the EGR hole you just cleaned out. (this is with the EGR still off) and you will then create a billowing cloud of carbon. After all that your done. Put it back together and don't overtighten any of the bolts in this whole process.
Scottelaxe
Jul 20, 2013 01:45 AM
1ATony
Jan 28, 2011 08:05 AM
jca1972
Apr 3, 2006 05:57 PM
uofa
Feb 24, 2006 10:02 PM
doowop22
Aug 5, 2004 06:18 PM
