just got a 93 civic coupe EX
Old Feb 24, 2006 | 04:19 PM
fightback's Avatar
Default just got a 93 civic coupe EX
i just got a coupe ex, mostly stock. im looking to turn this into a project car. what would be the best modifications to start with? dont have a lot of money right now
Old Feb 24, 2006 | 04:23 PM
96dxpower's Avatar
Default Re: just got a 93 civic coupe EX (fightback)
if youre low on cash cut the springs, maybe 3 coils throw some rotas on and youll be good til you get some cash
Old Feb 24, 2006 | 04:42 PM
fightback's Avatar
Default Re: just got a 93 civic coupe EX (96dxpower)
i have between 500 and 1000 to spend right know
Old Feb 24, 2006 | 04:44 PM
Syndacate's Avatar
Wait, what do uw ant to make it project as? If you want it to be a show car, than probably dropping it like he said would be an okay place to start, paint calipers and ****, but if u mean like, mechanically so it's puttin out 300whp, best place to start is intake/exhaust (complete), and headers..
Or an exhaust tip, not sure how u want to budget it or what u want to turn it into
Old Feb 24, 2006 | 04:45 PM
fightback's Avatar
Default Re: (Syndacate)
i dont really care what it looks like more just want to increase handling and power
Old Feb 24, 2006 | 04:57 PM
96dxpower's Avatar
Default Re: (fightback)
if you want handling and power than save up money for the GOOD ****
1000 bucks can get you a good damper kit
Old Feb 24, 2006 | 07:58 PM
biggnutz123's Avatar
i would keep saving for a good swap then probly do the brakes and suspention after that.
Old Feb 25, 2006 | 08:34 AM
fightback's Avatar
Default Re: just got a 93 civic coupe EX (biggnutz123)
what kind of engine swap would u recomend
Old Feb 25, 2006 | 08:37 AM
Lewy. Dee Ayy's Avatar
https://honda-tech.com/zerothread?id=878010
Old Feb 25, 2006 | 10:00 AM
fightback's Avatar
Default Re: just got a 93 civic coupe EX (WhiteOut)
what kind of damper kit would u suggest and how hard is it to install
Old Feb 25, 2006 | 10:33 AM
Mugen112's Avatar
I would ALWAYS do suspension first, then brakes, then after those two are done, i would invest in a bigger motor. But if you are dying to get a motor in there for a little bigger kick, then I would say get an LS (b18b). They are fairly cheap and easy to find, and once you get a little more money, you can piece together a turbo kit for it for practicaly nothing. Also, the swap is non-vtec and should be fairly easy for a first timer (if you are new to hondas). good luck with it! ej1's!!!!
Old Feb 25, 2006 | 11:09 AM
Sean Juan's Avatar
Default Re: (Mugen112)
Always suspension first.
Old Feb 25, 2006 | 05:17 PM
fightback's Avatar
Default Re: (Grip King)
what kind/ company suspension mods would you guys recomend
Old Feb 25, 2006 | 05:19 PM
96dxpower's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fightback &raquo;</TD></TR><TR><TD CLASS="quote">what kind of damper kit would u suggest and how hard is it to install</TD></TR></TABLE> pretty easy. 2 nuts on each shock in the engine bay. bolt on top and bottom of each fork. 2 bolts each shock for the brake lines. and there goes the fronts. the rear has 2 nuts in the trunk. and a bolt thats connected to the lca and bam, there goes the rears. reverse the process for the install check out the suspension forum https://honda-tech.com/zeroforum?id=54
Old Feb 25, 2006 | 05:29 PM
fightback's Avatar
thanks that dosnt sound to rough
Old Feb 25, 2006 | 06:04 PM
96dxpower's Avatar
and if the rear LCA is in the way you can drop that down a BA BAM i dont remeber wt sockets you use but i think its one of these 12 14 17 19. 2 of the four or even 3 of the four. ill find when i change mines out next weekend
Old Feb 26, 2006 | 11:12 AM
fightback's Avatar
Default Re: (aallbbeerrtttttt)
if i am going to change out the suspension should i worry about throwing in front and back sway bars as well?
Old Feb 26, 2006 | 11:27 AM
strtciv93's Avatar
turbo the d.
Old Feb 26, 2006 | 11:55 AM
Sketch_hs's Avatar
Default Re: (strtciv93)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by strtciv93 &raquo;</TD></TR><TR><TD CLASS="quote">turbo the d.</TD></TR></TABLE>
best idea so far.
Suspension and brakes too
Old Feb 26, 2006 | 03:28 PM
fightback's Avatar
Default Re: (Sketch_hs)
ive heard there are some problems turbo charging the d engine is that true?
Climbtrees
15
Feb 16, 2011 06:46 AM
pete332
Southwest (Sales)
Sep 18, 2010 10:14 PM
steve_s
20
Jan 1, 2003 06:32 PM
HondaVtec139
Jul 8, 2002 08:39 PM
CTR94Joes
Feb 13, 2002 02:52 PM
