geting to the fuel pump
Old Feb 24, 2006 | 03:33 PM
accordredliner's Avatar
* B A N N E D *
Default geting to the fuel pump
how do I get to the fuel pump on a 95 v6 accord?
Old Feb 24, 2006 | 03:40 PM
jfish's Avatar
Default Re: geting to the fuel pump (accordredliner)
97 had to drop the tank
Old Feb 24, 2006 | 03:46 PM
* B A N N E D *
i heard u have to remove the rear seats
Old Feb 24, 2006 | 03:58 PM
P_Adams's Avatar
The 5th Gens' require the removal of the tank to gain acess to the fuel pump (Tank Mounted)
On the 6th Gens', Honda got smart and incorporated an access panel in the trunk floor to gain access to the pump. Lucky them
P
Old Feb 24, 2006 | 04:01 PM
BLKFLSH's Avatar
Default Re: (accordredliner)
I think you can test the sending unit and wires from behind the seat. But i'm pretty sure to get to the fuel pump you have to drop the tank.
Old Feb 24, 2006 | 04:59 PM
Dmc1's Avatar
You have to drop the tank.
Old Feb 25, 2006 | 11:33 AM
iam7head's Avatar
Default Re: (Dmc1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dmc1 &raquo;</TD></TR><TR><TD CLASS="quote">You have to drop the tank.</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dmc1 &raquo;</TD></TR><TR><TD CLASS="quote">You have to drop the tank.</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dmc1 &raquo;</TD></TR><TR><TD CLASS="quote">You have to drop the tank.</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dmc1 &raquo;</TD></TR><TR><TD CLASS="quote">You have to drop the tank.</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dmc1 &raquo;</TD></TR><TR><TD CLASS="quote">You have to drop the tank.</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dmc1 &raquo;</TD></TR><TR><TD CLASS="quote">You have to drop the tank.</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dmc1 &raquo;</TD></TR><TR><TD CLASS="quote">You have to drop the tank.</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dmc1 &raquo;</TD></TR><TR><TD CLASS="quote">You have to drop the tank.</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dmc1 &raquo;</TD></TR><TR><TD CLASS="quote">You have to drop the tank.</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dmc1 &raquo;</TD></TR><TR><TD CLASS="quote">You have to drop the tank.</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dmc1 &raquo;</TD></TR><TR><TD CLASS="quote">You have to drop the tank.</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dmc1 &raquo;</TD></TR><TR><TD CLASS="quote">You have to drop the tank.</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dmc1 &raquo;</TD></TR><TR><TD CLASS="quote">You have to drop the tank.</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dmc1 &raquo;</TD></TR><TR><TD CLASS="quote">You have to drop the tank.</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dmc1 &raquo;</TD></TR><TR><TD CLASS="quote">You have to drop the tank.</TD></TR></TABLE>
are we clear yet?
iam7head's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by accordredliner &raquo;</TD></TR><TR><TD CLASS="quote">i heard u have to remove the rear seats</TD></TR></TABLE>
civic and teg only
Old Feb 25, 2006 | 09:51 PM
YeuEmMaiMai's Avatar
to get to the fuel pump on a 5th gen accord, you have to drop the tank. you can get the the fuel sending unit but not the pump through the back seat or trunk..
This is why I have never let my 5th gen (or 6th gen) below 1/4 tank. It's a PITA to replace that fuel pump. If your tank is full you might want to siphon the gas out before you drop the tank to make it easier to handle. Also use a rubber mallot and brass punch to prevent sparks when you remove the retainer rings. of you use steel parts, there is is a very good chance you will go up in flames.....I've seen it happen
On the 1998 and newer cars you go through the trunk via the access cover.
Modified by YeuEmMaiMai at 1:06 AM 2/26/2006
Old Feb 25, 2006 | 10:18 PM
BLKFLSH's Avatar
Default Re: geting to the fuel pump (YeuEmMaiMai)
And make sure you have disconnected everything. Fill tube, wire harness (for pump and sending unit), and fuel lines. Before dropping the tank. You may want to rinse out the inside, then make sure it is completely empty before putting it back up. Lighter, is better.
Old Feb 26, 2006 | 02:41 AM
* B A N N E D *
What is the path of the fuel pump power wire from the engine bay? I want to make a kill switch for the fuel pump. Since my kill switch will be wireless (remote control), I want to put the relay as deep as possible and in a place not easily accessible.
thedudefromjerz
Nov 5, 2007 10:02 AM
B Series JuNky
Aug 6, 2007 10:20 PM
fatboyslim44
Apr 29, 2007 07:34 PM
shawn_crx
Mar 8, 2005 06:35 PM
dvp95
May 29, 2003 09:40 PM
