Can you use 90-91 corners on 88-89 fenders?
Old Feb 24, 2006 | 03:28 PM
TurboEM1's Avatar
Default Can you use 90-91 corners on 88-89 fenders?
Can you use 90-91 crx corner lights on an 88-89 fender? Is there a way to get the clips or whatever to hold them on? I like the look better of the 90-91 lights. Thanks
Old Feb 24, 2006 | 04:04 PM
xaine's Avatar
Default Re: Can you use 90-91 corners on 88-89 fenders? (TurboEM1)
yes you can as long as you swap the mounting clip set up
Old Feb 24, 2006 | 04:06 PM
si0385.'s Avatar
Default Re: Can you use 90-91 corners on 88-89 fenders? (xaine)
yea but its not a direct bolt up
Old Feb 24, 2006 | 04:46 PM
CRXBart's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xaine &raquo;</TD></TR><TR><TD CLASS="quote">yes you can as long as you swap the mounting clip set up
don't forget the headlight brackets are different.
Old Feb 24, 2006 | 05:12 PM
ludesrv's Avatar
You can do it, but you need to switch the headlights and fenders over. Well no the whole fenders, but those clips usually break and it's easier to swap a fender and to cut holes and make them fit.
ED3 SEDAN-GSR
Nov 3, 2012 10:45 PM
anj_jmv
21
Oct 20, 2007 04:47 PM
vthree
Feb 17, 2006 02:24 PM
teamrushhatch
Oct 21, 2003 09:17 AM
rasta420
13
Jan 6, 2003 04:11 PM
