Handata Stage 2 and VAFC - A Conflict?
Old Mar 28, 2002 | 07:12 PM
RedTeg95's Avatar
Default Handata Stage 2 and VAFC - A Conflict?
I was wondering if anyone out there had this combo installed in there teg and if so are there any conflicts between the 2 Vtec controllers? I have a VAFC and plan on getting a hondata stage 2 for logging.
Old Mar 29, 2002 | 05:40 AM
canuck-mx6's Avatar
Default Re: Handata Stage 2 and VAFC - A Conflict? (RedTeg95)
Why would you want to keep the VAFC? If you understand what Hondata does, you will realize that you do not need the VAFC anymore once you get Hondata. The Hondata uses the correct fuel and timing maps before and after VTEC, and you can set the VTEC point of your choice.
The VAFC by comparison does not use the correct map if you change the VTEC point. You have to do some fuel correction, and there is no way to change the timing. If you get a Hondata, the words of advice, lose the VAFC!
Old Mar 29, 2002 | 09:19 AM
2K_TEG's Avatar
Default Re: Handata Stage 2 and VAFC - A Conflict? (canuck-mx6)
Don't use both together.
Old Mar 29, 2002 | 09:33 AM
Leimokei's Avatar
New User
Default Re: Handata Stage 2 and VAFC - A Conflict? (2K_TEG)
you would use your hondata as your ecu...no need for vafc...the hondata would be tuned to your car already..sell the vafc...unless you want it for show
LudeLooker
Mar 28, 2004 01:53 PM
pootie.teng
Jan 22, 2004 11:40 AM
(__________)
Sep 17, 2002 11:40 PM
avsrule414
Sep 3, 2002 12:35 PM
avsrule414
Jul 29, 2002 01:26 PM
