Noobish cam seal question question?!?! h22a
Hi guys,
this is probably fairly obvious but I just wanted to be sure... Im ordering some cam seals for the h22 engine, do I need 1 per cam? i.e. 2
Thanks
Thanks
If your ordering like a billet cam seal you only need one it goes on the intake cam the distributer goes on the other cam. If your ordering the ones that go on the side with the cams you need two.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by durand202 »</TD></TR><TR><TD CLASS="quote">If your ordering like a billet cam seal you only need one it goes on the intake cam the distributer goes on the other cam. If your ordering the ones that go on the side with the cam gears you need two.</TD></TR></TABLE>
fixed
fixed
These are the billet cam seals yes, I have one so I guess I dont need to order another.
Thanks for the prompt reply
