LIL PROBLEM
Old Feb 24, 2006 | 08:18 AM
B SERIES US's Avatar
Default LIL PROBLEM
i just installed a d15b vtec in my 91 hatch (dx) i left it dpi and obd-0...the thing is that the car has no power and it reaches 3500-4000 and just dies..now the dizzy obd-0 had to be modded,if you done this before you know what i mean.but i dont think its the timming, mech or ing..the stock motor had no prob..and ran fine.....so whats is you input let me know thanks...peace
Old Feb 24, 2006 | 08:20 AM
ludesrv's Avatar
Your retarded for leaving it DPFI. Switch it to MPFI and use the D16A6 distributor and modify the mounts to fit the OBD1 engine.
You are probably running so lean on that engine by being dpfi that it's damaging it.
Also, if you think you have vtec now you are wrong. You will need to modify your harness to mpfi and for vtec. I suggest the switch to OBD1 and uding the D16Z6 ECU.
Old Feb 24, 2006 | 08:23 AM
Crimson_Tide's Avatar
Default Re: (ludesrv)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ludesrv &raquo;</TD></TR><TR><TD CLASS="quote">Your retarded for leaving it DPFI. Switch it to MPFI and use the D16A6 distributor and modify the mounts to fit the OBD1 engine.
Also, if you think you have vtec now you are wrong. You will need to modify your harness to mpfi and for vtec. I suggest the switch to OBD1 and uding the D16Z6 ECU.</TD></TR></TABLE>
please dont ever do an engine swap and keep it dpfi
-Josh
Old Feb 24, 2006 | 08:25 AM
ludesrv's Avatar
I can't beleive it even runs! He must of shopped the harness to get 4 injctors flowing unless only 2 are flowing. But then how would it even run! This guy blows my mind.
Old Feb 24, 2006 | 08:27 AM
wow thats is about crazyist thing i ever heard..running lean why dont the d15b motor that came out of it ever run lean?and besides it does detonate.
Old Feb 24, 2006 | 08:30 AM
si0385.'s Avatar
Default Re: (B SERIES US)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B SERIES US &raquo;</TD></TR><TR><TD CLASS="quote">i just installed a d15b vtec in my 91 hatch (dx) i left it dpi and obd-0...</TD></TR></TABLE>
that needs to change ASAP
i wouldint even drive it like that
Old Feb 24, 2006 | 08:44 AM
Max Kling's Avatar
Just convert everything.
I did the swap in my 89 hatch and it NEVER ran right until I finally broke down and converted it to OBD 1. That way you dont have to put up the obd 0 dist so it fits, when you do that timing is a bitch to get on and stop it from leaking oil.
There are so many write ups on how to convert that it isnt that hard. Just shave down the drivers side mount so it dosent hit the timing belt and put the engine in. Its one of the easiest swaps someone can do and only takes a few hours.
Old Feb 24, 2006 | 09:06 AM
Ass$nyper's Avatar
Pirate General...YARRRR
Default Re: (Max Kling)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Max Kling &raquo;</TD></TR><TR><TD CLASS="quote">Just convert everything.
There are so many write ups on how to convert that it isnt that hard. Just shave down the drivers side mount so it dosent hit the timing belt and put the engine in. Its one of the easiest swaps someone can do and only takes a few hours.</TD></TR></TABLE>
Boomslang makes a great harness
Rywire does too
I've used both with no problems.
Old Feb 24, 2006 | 03:35 PM
Tippyman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B SERIES US &raquo;</TD></TR><TR><TD CLASS="quote">why dont the d15b motor that came out of it ever run lean?</TD></TR></TABLE>
Because the stock motor was made to run off of DPFI!!! Your new motor is not!!!
Old Feb 24, 2006 | 09:59 PM
Max Kling's Avatar
Default Re: (*** Sniper)
I used a boomslang harness and the rywire dist. conversion harness.
Those guys are totally awesome and helped out so much. Hell they will even make your DPFI harness into a MPFI harness that way its a 100% P & P swap.
So all that was left was rung 4 wires to the O2 and 2 wires and ground one for the vtec sol.
94blkHB
Jul 20, 2007 07:20 PM
racenrockj06
Jan 18, 2005 11:40 PM
s2kkk
Feb 18, 2004 06:32 AM
91sleeper
10
Sep 8, 2003 08:24 PM
Sirex
Mar 15, 2003 05:54 PM
