Speedometer cable... broken????
so i got my transmission swapped out.... i hooked up the speedo cable... go to test drive the car and the speedo ain't workin...what could be the problems????
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ghost_ryder35 »</TD></TR><TR><TD CLASS="quote">probalbly just popped out of the tranny</TD></TR></TABLE>
most likely
most likely
there is a clip that is suppose to go around it. Most people just jam the cable in though and dont put the clip on. if you get it in there deep enough you should be ok but I would put the clip on
The very bottom. If you look at the Tranny where the cable plugs in you will see a nipple sticking up with a hole in it. On the outside of that nipple there is a groover for a C clip to clip onto it holding the cable in place once it is slid into the nipple plug. Sorry, best way I could think of describing.
andrewsmith85
Jun 18, 2008 03:30 PM
