i need a new tranny, will this work?
Old Mar 28, 2002 | 06:22 PM
crxzc's Avatar
Default i need a new tranny, will this work?
i have a 91 crx si with a zc swap and my tranny is bad. i have my 140,000mile si tranny with my zc right now. the tranny grindes 3rd and has a hard time going into 1st sometimes. my friend has a 89 civic si hatchback and he is doing a b16 swap. can i use his tranny. as long as i use his flywheel, right? any help would be great.
http://members14.clubphoto.com/kev56...ner-2362.phtml
Old Mar 28, 2002 | 06:32 PM
keithv's Avatar
Default Re: i need a new tranny, will this work? (crxzc)
i think you just have to use his flywheel/clutch assembly with the tranny.
its your friend's stuff, so at least try it out!
Old Mar 28, 2002 | 07:08 PM
Lt. Dan's Avatar
Default Re: i need a new tranny, will this work? (breaka_1_9)
It'll mate up just fine... use your 91 clutch/flywheel.
Dan
Urban Business
Guest
Posts: n/a
if you have a stock si trans on there now your friends will work just fine.
Old Mar 28, 2002 | 07:17 PM
crxzc's Avatar
Default Re: i need a new tranny, will this work? (TorteX)
i heard that 88-89 and 90-91 L3 transmissions are different. are they the same?
Old Mar 28, 2002 | 08:35 PM
flat-blk-HB's Avatar
i think the only oddball of the trannies is the 1988 tranny..something about the splines or something not really sure....so it should work fine....
Old Mar 28, 2002 | 09:30 PM
BigBlockCRX's Avatar
New User
check your motor mounts first.. if the tranny one is bad, or the rear mount is bad/broken it will mess up your shift alignment, and will be hard to shift..
your tranny might be ok afterall
Old Mar 28, 2002 | 09:38 PM
ED8DX's Avatar
Default Re: i need a new tranny, will this work? (89EF-BCUMBIE)
and the friction plate diameter is different.
Old Mar 29, 2002 | 05:02 AM
virginia_dude's Avatar
Default Re: i need a new tranny, will this work? (crxdx)
The Clutch plate diameter is dictated by the flywheel used thats what the clutch size has to match, the spline count is an issue with ONLY the 1988. I hava a ZC with a 1990 SL3 Si trans with the ZC Flywheel and a 9'1 112 mm clutch assy. in a 1989 Civic DX hatch.
Old Mar 29, 2002 | 09:33 AM
rainforest's Avatar
Default Re: i need a new tranny, will this work? (virginia_dude)
i looked on my dx tranny and it says L3 ...is this an si tranny
Old Apr 1, 2002 | 05:23 PM
Default Re: i need a new tranny, will this work? (rainforest)
Not at all, I have a DX AND a Si Trans BOTH with L3 on them. My understanding is the Difference between the DX and The Si Trans is the lower ring and pinion ratio with the Si. AND some bearing size issues, Si has beefier bearings.
tkda
17
Feb 10, 2009 10:39 AM
Xemu
Oct 6, 2006 10:10 PM
ls_vtec_crx
33
Apr 3, 2004 09:19 AM
Civic138
Aug 25, 2003 03:01 PM
cr-x si
Jun 22, 2003 12:49 PM
